Question about Sharper Image Hybrid GP (SI724) Air Purifier
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes on. I can't get it to stop. Vacuumed it turned it upside down etc. cleaned it like crazy and still can't fix it.
  • 2 more comments
  • itmanatwork Nov 16, 2008
    SI724
    The filter in this unit will not work, it makes the unit stay in dryer mode.
    I have three units, the filter from a working unit works ok in this unit.
    The filter is apparently the proble.
    What can I do to the filter to make it work?
  • jzriny Jan 19, 2009
    I have re cleaned the unit, blown compressed air and it still makes the popping and goes into drying mode.
  • flankan Apr 20, 2009
    I have the same exact problem with both of my units!
  • Rich Finnigan May 06, 2009
    When cleaning the grid, the plastic coating on the fins of the grid have become damaged, and the bare metal seems to be causing the arc and loud popping sound. Is there any way to fix this, or can I purchase a replacement grid?
  • 5,568 Answers
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Posted on Oct 10, 2008
I wash mine with warm water then wipe it down with paper towels, whip it dry outside and then let it dry really well . I have never had a problem. The "popping sound" occurs when it's not dry enough to run in regular mode.
Posted on Mar 28, 2010
Sharper Image Hybrid GP (SI724) Air Purifier makes a poping noise and there is a arc lighting in the back
Posted on Feb 10, 2010
Clean it with a moist paper towel. Mine never has made a peep!
Posted on Aug 22, 2009
Sharper Image Midi S1853 / NO BREEZE
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Jan 12, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the lower section of the grid. Can this be fixed? How? The unit goes into "drying" mode and the fans still run, but I...
had the same problem, sparking in the lower section. i cleaned the grid blades on the filter with a scotch brite pad thoroughly in the area that was sparking and cleaned the corona wires inside the back of the unit gently by rubbing with light grade sandpaper. the unit runs like new. give it a try.
Nov 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Sharper image ionic cleaner wire problem
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 15, 2009 | Ionic Pro (HW-020002) Air Purifier
Cleaning light stays on
Jan 18, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Making sizzling noise
Unfortunately Sharper Image has discontinued support on the product line.  There was a recall going on with the product but since the company is chapter 11 right now, I don't think it is being honored right now.
What happened was Consumer Reports ran a test on ionizers, Sharper Image received a bad score and filed a lawsuit.  They lost the suit and had to pay all legal bills.
EPA has reported that using ionizers in a house or business may be harmful to your health.  You can read an article about it on their website.
The Consumer Products Safety Commission is going to release a final report on all ionizers by the end of the year.  Their decision may discontinue all sales of any ionizers in the United States.  This industry should have been regulated years ago just by the EPA data alone and for some reason it has been ignored.
Sep 10, 2008 | Sharper Image Professional Plus Ionic...
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image S1737 Shorting
Sharper Image Ionic Breeze products are no longer supported because they were proven to be ineffective by Consumer Reports causing legal disputes that the company lost. This legal dispute put the company out of business.
Here is an article about Sharper Image
Here is an article from the EPA about Ionizers
The Consumer Products Safety commission is going to release a report on all ionizers by the end of the year. Their decision could make ionizers a thing of the past.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze midi
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
Here is a link on the Chapter 11 report
Here is an EPA report on ionizers
Jun 18, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Hybrid GP  (SI724) Air Purifier Logo
1,490 people viewed this question
Top Sharper Image Air Purifiers Experts
martinmarty
Ken Thomas
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
