Question about HP Photosmart C4280 Aio Printer
Running windows 95: Cannot get C4280 program on computer.
Mother, purchased C4280: She does not have internet. Do I have to install
a usb cable since she does not have internet? Second, tried to program printer with cd. this is the message I keep getting:
The HPZSTUB> EXEfile is linked to missing export KERNEL 32. DLL I S
Debugger Present. Don't know what in the world this means. Third: Went under printers, Does not have C4280 to pick from. Is there any other printer choice I can choose from to add this printer.
    Scholar:
  • 77 Answers
Hi Dannysone,
If you look at the minimum system requirement(on the box or cd) you will find that win 95 is not supported. You probably can still use the printing function by using the hp deskjet c550 when you go to add printer. You really need to upgrade the computer. You probably will still be able to use the picbridge functionality on the photosmart to print pictures directly from the camera but thats about it.
hope it helps
cheers
Posted on Oct 10, 2008
I have a hp printer/scanner 3510 and hp computer, the printer works fine but it won't scan!! the lcd screen says, "the computer is not responding. check if the usb cable is attached" the cable is...
Unplug the USB cable to the printer. Uninstall the HP printer software. Reboot. Reinstall the HP printer software and WAIT until the installation program tells you to plug in the USB cable.
Mar 09, 2014 | HP Photosmart C4280 Aio Printer
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Can a Windows 95 have a usb port installed
Yes.
Load the required driver from Microsoft but it will not be USB 2 only USB 1.
Oct 16, 2010 | Computers & Internet
HP C4280 does not scan
Hello !
Your print driver may be corrupted. So, give this a try:
Delete your AIO icon from Printers and Faxes
Download the latest driver for your operating system from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3192753&
Disconnect your USB printer cable
Restart your computer
Reconnect your USB printer cable
Your computer should see your AIO and install the new driver.
If your computer does not see your AIO, your USB printer cable is faulty or try another USB port on your computer.
Hope this helps.
Sep 16, 2009 | HP Photosmart C4280 Aio Printer
Get message USB not connected when trying to scan
Right mouse click on my computer then click on hard were click ondevice manager, then click on port there may be yellow sign in usb port keepiung cd install it. 2/ if not work change usb cable to check ithink ucan solve your problem. 3 if not solve or u have desk top computer change usb card which we keep on on mother board slot. as amodeam and other card thank
Jun 19, 2009 | HP Photosmart C4280 Aio Printer
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Mar 13, 2009 | HP Office Equipment & Supplies
Can't install HP Photosmart c4280
You have to know first if your printer is Vista compatible.
If yes, you need the vista drivers in order to get your printer connected with vista.
When the system prompt for the driver, click BROWSE and Select the location
Open the folder when the downloaded driver is and click OK
This must be fixing your problem
Oct 29, 2008 | HP PhotoSmart C4280 Laser Printer
Shadow not connecting on internet sharing..
Uninstall ActiveSync.
Reboot.
Download ActiveSync 4.5 from Microsoft.
Install ActiveSync
Do not connect the phone to the PC via USB yet.
In the phone, goto Internet Sharing, select the internet connection and select "USB", and click connect.
Afterwards, connect the USB to the PC.
Wait up to 30 seconds and vola! You have internet access.
Jul 07, 2008 | HTC Shadow Smartphone
C-150 OLYMPUS DIGITAL CAMERA
By connecting the camera to a computer with the provided USB cable,
images on a card can be transferred to the computer. Some OS's (operating
systems) may need a special setup when connecting to the camera for the
first time. Follow the chart below. For details on the procedures in the chart,
refer to the “Reference Manual” on the CD-ROM and the “Software
Installation Guide” (included in the CD-ROM package).
Identifying the OS
Windows 98/98 SE
(Second Edition)
Windows 2000
Professional/Me/XP
Mac OS 9.0 - 9.1/OS X
*OS 8.6: See below.
Connecting the camera to a computer using the provided USB cable
Installing the USB
driver for Windows 98
Confirming the computer recognizes the camera
Downloading image files
Disconnecting the USB cable
Even if your computer has a USB connector, data transfer may not function correctly if
you are using one of the operating systems listed below or if you have an add-on USB
connector (extension card, etc.).
● Windows 95/NT 4.0
● Windows 98/98 SE upgrade from Windows 95
● Mac OS 8.6 or lower (except Mac OS 8.6 equipped with USB MASS Storage support
1.3.5 installed at the factory)
● Data transfer is not guaranteed on a home-built PC system or PCs with no factory
installed OS.
You can view images using: graphics applications that support the JPEG
file format (Paint Shop Pro, Photoshop, etc.); Internet browsers (Netscape
Communicator, Microsoft Internet Explorer, etc.); CAMEDIA Master
software; or other software. For details on using commercial graphics
applications, refer to their instruction manuals.
Jan 31, 2008 | Olympus Camedia C-150 Digital Camera
I cant install my hp photo smart c4200 series printer becauce I have lost the disk
Jan 30, 2008 | HP PhotoSmart C4280 Laser Printer
HP Photosmart C4280 Aio Printer Logo
Seeker5211
Seeker5211
