COPIER PRINTING BLANK
My copier was working properly, when one day it just started printing blank papers. I replaced my toner with MT 102A thinking that it is the problem. However, the copier still printing blank copies. I noticed that when I opened the compartment and switched the copier on, the toner did not rotated, shouldn't it be rotating while the copier is on service? Please can anybody help me before I go to my technician. thank you very much. My copier is MINOLTA CSPRO EP 1052
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your corona or high voltage charger . meanwhile you can remove the developer tank rotate it manually & if it rotate fine ,remember that their is a door actuation switch that wouldnt allow the copier to rotate while the door is open . you can remove the tank & use hand to mark the toner surface then restore it & on the copier ,then remove it to know if the mark rotate . if your corona wire cut, burn or if the charger is spoiled all these can cause blank copy
Posted on Oct 11, 2008
I JUST BOUGHT A SHARP AR-5127 COPIER..WHEN IT COPIES, IT BRINGS OUT BLANK PAPER. I REMOVED THE CATRIDGE AND IF I TURN IT UPSIDE DOWN,SOME BLACK DUST COMES OUT...PLEASE SOMEONE HELP ME
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
mvincentc
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Make sure you remove the seal tape on the new cartridge thats why it making noise then install properly.
Bizhub Copier C350 quit "printing", no error codes
CAUSE: A failed PWB-MC board.
SOLUTION: Replace PWB-MC (p/n 4036-7811-01).
try and unplug the machine while its on first wait 5-min and plug back on if that won't help you will need the above board
good lock
Mar 11, 2009 | Office Equipment & Supplies
ImageRunner 400S works, but prints a blank page
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Aug 13, 2008 | Canon imageRUNNER 400S Copier
My copier gives me blank sheets
try printing a user data print,if it still blank then check the shutter for the lens if they are operating.if problem persists call me on 592-662-2006 i will be happy to assist.
Jan 31, 2008 | Canon imageCLASS MF6530 All-In-One...
Paper comes out with nothing on it
Possibly sounding silly here, (again) but have you removed the seal from the toner cartridge (This is a breakaway plastic tab, connected to a length on plastic, which seals the toner for transit)
If this has not been removed from the cartridge then it fails in just the way you are describing
Oct 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Oct 04, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
167 people viewed this question
jasbo
jasbo
