Phillips # 50p8341 comes on everyonce in awhile. Sometimes it wont come on and the power light will start to blink
    Scholar:
  • 142 Answers
Hello! Your set needs the board that has the microprocessor on it. It is called the "process pcb" and is located on the left side as you look into the back of your unit {with the back cover off, of course!). It stands straight up and is plugged into the signal (or "tuner"pcb). They cost about $100 and are available from tritronicsinc.com. All you have to do is unplug the board from the connector by pulling it straight up. Then you just plug the new board in. Make sure it seats properly. The board is approximately 4" by 4" square. VERY easy repair...you can do it and save BIG $. Just make sure you do it when the ac is unplugged!!! Good luck!!!
barneyluc
Posted on Oct 10, 2008
97 pontiac grand prix
Check about your ignition switch.
Aug 27, 2012 | 1997 Pontiac Grand Prix
Starts sometimes wont idle or accelerate
try checking your egr valve pressure sensor i have a 96 eddie bauer explorer and had the same problem and only showed me a code for a oxygen sensor malfuntion and replaced both and it cured it
Jun 23, 2010 | 1996 Ford Explorer
Power light always on but no pic
Make sure it is off when you unplug it, do not use for at least a few days then.try again. It worked for mine.
Jun 20, 2009 | Philips 50P8341 50" Rear Projection...
My memeroy card will not save files right
try deleting all your game files and svaing again. =)
Mar 27, 2009 | Sony PlayStation 2 (PS2) Console
ABS light comes on, then Battery, Dash lights flash
check the alternator it could be draining the battery
Jan 24, 2009 | 2000 Dodge Stratus
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
My phillips model # 50P8341 periodically shuts off on its own. When I turn it back on it plays for a little while then shuts off again.
the set is going into shutdown mode. does the power indicator blink when it shuts down. If so how n=many blinks does it blink?
Apr 28, 2008 | Televison & Video
Rear projection
Considering that in both cases, the set will turn on but not stay on, indicates either a condition of overheating due to a failed fan or it could be a component going into thermal runaway in the power supply itself that is causing the fault.
This is not a safe area to probe around in since there are capacitors that may contain a charge for a fairly long time.
If the fan cannot be heard, this is probably a cheap repair, otherwise, get an estimate first.
Jan 11, 2008 | Philips 50P8341 50" Rear Projection...
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
