Acer Laptop, screen is blank, laptop works with external monitor.. does anyone know how or what to fix?
  • 4,338 Answers
The internal video circuitry on the system board is bad. This requires a new system board to fix the problem.
Joe
Posted on Oct 10, 2008
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
Hello, I cannot connect my ACER ASPIRE 1640 to an external monitor. I only have a predeterminated monitor as configuration option. Please, help me. Thank you Luca.
Alright 1) Turn your laptop off, connect the cables to your external monitor such as a t.v, monitor screen, through your apropriate source such as HDMI, VGA, or S-vdieo which ever one you are connecting it to. Turn your external Monitor on, and if it is a t.v make sure it's the the correct input otherwise it won't work. Then Turn your computer on, once your computer is in the Operating system and completly loaded, Then you want to press the FN button + the F5 button to swtich your display from your laptop to your external screen. There is a little Icon that appears on the screen that lets you know that it is switching either it's duplicating, to your external monitor only or back to your laptop screen, your screen may go blank for a second once your made your choise. Then you should be god to go.
2) If it doesnt work, you might want to try loading your computer first and then plugging in the cables and turning your tv on.
3) If that doesn't work, then maybe your FN button is disabled, and you need to enable it in acer windows mobility aplication. If you have question let me know.
Feb 06, 2011 | Acer Aspire 5100-3357 Notebook
I have an Acer Aspire 5315, the screen has just been black for a couple of days now. the two green lights on the front of the laptop are on, and seem to stay on constantly. So I am presuming there is still...
Lea, listen press F2 whilst booting up to get into boot sequence,there you can enable corect loading procedure of your hardware.Otherwise if you have an OS re install that,or even if you have an external monitor socket on the side of your pc ,,plug an external monitor in to see if your pc is working but the screen has failed,so theres some options!--Good Luck!
Davey Snake!
Oct 21, 2010 | Acer Aspire 5315 Notebook
Blank screen on my acer laptop, it boots up, and i have put it on an external monitor, and it brings the screen up on the laptop,also tried changing the screen from 1 to 2 so the lcd is not broken, tried...
If an external monitor works fine then maybe you're having issues with the LCD's backlight. It happened to my laptop and I had to replace the whole LCD itself.
May 11, 2010 | Acer TravelMate 7120T (91.42A01.605) PC...
Acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Aug 29, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Need help for Acer Aspire ONE MODEL # ZG5 screen does not work?My Acer Aspire ONE MODEL # ZG5 notebook is show that the power is on, but the screen is black. I can hear the computer running, but there is...
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Mar 26, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 3000
Have you tried to disconnect the external monitor and just booting to the laptop? If this works, then use the "e" key next to the power button to add the second monitor.
Jun 20, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
