Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
My kitchenaid professional mixer does not work, tried replacing carbon brushes with no luck, obviously tried new fuse as well...nothing happens when switch is turned on, faulty switch?
  • KitchenAid Master
  • 5,568 Answers
It's doubtful that the switch is at fault but either the field or the armature winding could be open. These are fairly easy to check once the innards are accessible, with any multimeter and a little understanding/experience.
I don't know how speed selection and regulation is done in that mixer but it may be electronic (as opposed to earlier electromechanical governors) and checking that section requires a little bit of knowledge about the components used.
When you replaced the brushes, did you notice anything about the surface they contact? The segments are made of copper and should appear shiny where the brushes contact, not discolored or burned-appearing. If they show signs of heat or charring, this could mean that the field windings are damaged.
Posted on Oct 10, 2008
    Genius:
  • 1,605 Answers
Checkt he switch and the motor contact. you might have too much carbon.
how old is the mixer?? it might be time to get a new one???
My Kitchenaid Mixer stopped working. Saw a mention of replacing the thermistor? Or is it the motor or control panel?
Make sure that the carbon brushes are not worn out or if you have already had them out make sure that they have been put back in properly. There is one corner ground off each brush that needs to line up with a blocking corner in the brush holder. Then get your multi meter out and check the unplugged main cable for continuity to the speed control panel. Then check each half of the field assembly for continuity from the speed control plate to a brush holder. Check you have no broken wires to the speed control plate. Check that the switch on the speed control plate is functioning. If all that tests OK I'd replace the phase board, it's worth not much and worth a shot.
Jul 28, 2017 | KitchenAid Food Mixers
My machine simply won't turn on .
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
Mixer - motor dead
I have heard similar problems when the mixer has been transported. It usually happens if the mixer is transported on its side. If there was any burned flour on the brushes the jostling of the mixer can cuse it to get between the brushes and the armature.
So check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Apr 21, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a kitchenaide mixer and now it will not turn on
Remove those plastic caps again and this time remove the brushes from the side of the mixing head. Inspect the curved surface of the brush and clean any carbonized flour from the surface - be careful not to damage the surface of the carbon brush.
When replacing the brushes make sure they go in the correct way - there is only one way, the brushes will not go in far enough if they are in the wrong orientation. Trial and error works, watching how far in the brushes go. once you have found the correct position, the brush will go in 1/4 inch further than the other three positions.
Apr 01, 2010 | KitchenAid 32685 Mixer
How do I replace the carbon brushes on my Kitchenaid mixer. I took them out but didn't pay attention to which direction the beveled edge lies. There is no "up" stamped on them.
do not know the device specifically, but with brushes in general it should be fairly obvious by inspecting the alignment of the brush housing to the rotor to determine the proper orientation. perhaps use a flashlight to look into the brush housing and try to see how it meets the rotor? chances are the "point" of the brush would be in the same direction as rotation. it may also be helpful to try one orientation and turn the shaft slowly by hand to confirm the brush is smoothly contacting the rotor..
Oct 18, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Ultra mixer has no power?
thease coal like things are carbon brushes and need to contact copper coils for mixter to work so replace the carbon brushes and it will work again
Oct 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
DONT WORK
Hi. Before you get too far, call kitchenaid parts to find out if they still have parts for your mixer. They no longer show a parts list for the KSM90 so your mixer may end up in the trash.
Go to mendingshed.com and select the Kitchenaid products button then select Kitchenaid mixer parts. Near the top of the page locate the button for the free kitchenaid service manual. Download the manual and read about the disassembly and reassembly of your mixer.
This manual does not cover your mixer but is a usefull tool for working on any mixer. Good luck with it.
If this solution has assisted you, please rate it. ricardok45
Apr 18, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KSM103 won't run
I had removed carbon brushes and when tried to start nothing happened kept removing brushes it eventually started
Dec 14, 2007 | KitchenAid KSM103 Professional 5 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
185 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
