Linsar LCD tv type L26HDF1-S has intermitent loss of picture, audio remains OK. Backlight still Ok. Blue screen in Aux Mode 4-S an 5. Turning off and then on brings back picture most times, but not always. Will be OK for 30 minutes or 10 hours dependent on its mood! All remote buttons work Ok for channel changes etc, with or without picture. Cant see any dry joints or iffy capacitors anywhere
  • dosdiver Oct 15, 2008
    Already checked visible connectors, forgot about the screen connectors hidden underneath the "works" Thanks for reminding me to do it properly next time !!
  • 19,396 Answers
That looks like a problem with the LCD ribbon cable, or the connector to LCD display.
Posted on Oct 10, 2008
  • Ginko
    Ginko Oct 10, 2008
    More than a problem with dry joints (modern pcbs have rarely this kind of problems) it can be a problem with the flat ribbon cable connecting to the LCD display.
    You need to take apart the tv and check the LCD cable and its connector.
    If you are not sure about what you are doing, or if the unit is under guaranty (less than one year old), then call the number listed on the owner manual to get assistance.
No picture on lcd tv.. What parts do I need to replace to fix the picture?
Hi John,
From what you have described, it seems that the tv is going in protection after 5 secs.
Though the backlight is there, but are you sure that all the cfls are glowing.
If one of the cfls is not working, the set will go off in the same manner.
If this is the case, disconnect the defective cfl and solder a 4700mf/2000v capacitor in its place. If this works, you either keep the set running like this or replace the defective cfl.
Otherwise, If all the cfls are ok and working, your inverter card if suspected to be defective.
Good luck
Feb 06, 2015 | Vizio Televison & Video
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
Blank screen with blue light
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Apr 26, 2011 | Panasonic SCBTT350 Theater System
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
Dec 15, 2010 | Televison & Video
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
Picture goes dark on different sections of screen intermitently then its ok for a while
Intermittent backlight lamps or backlight inverters.
If this model has an auto-dimming feature, try disabling that feature.
Oct 20, 2009 | Samsung LA46A550 46 in. HD-Ready LCD TV
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Oct 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
Image lost after 5 min turning on the tv, sound was ok.
I would suspect overheating of an electric component in the power supply of the lamp (backlight) of your lcd tv. bring it in for repairs.
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
223 people viewed this question
Top Televison & Video Experts
