Question about Sony PlayStation Portable (PSP) Console
Psp best custom firmware
Okay i have a slim psp ang just got pandora's battery i know how to put any cfw on it put i don't know which one. i don't have any umd's because i am going to use iso's.what should i choose im not sure if i should use 1.5 or 4.01m33 or anything i am confused
  • kevman95 Oct 11, 2008
    thank you
  • 30 Answers
3.71 M33-3 is the best in my opinion it is very stable and easy to install.
Please rank solution.
Posted on Oct 10, 2008
How to add games in PSP slim v6.31? i upgrade v5.03 to v6.31.. and now i dont know how to add games.
That was a bad idea. You need to downgrade again, and you need a pandoras battery to do that. I believe you accidentally updated from custom firmware to a more recent OFW version. You can't add games with OFW, only CFW.
Mar 14, 2011 | Sony PSP Slim and Lite Console
Tip
"Hack your PSP" guide
1.)Here are some termins i will use:
OFW-Original firmware,this is your system software
CFW-Custom Firmware,Modified firmware
HEN-Homebrew(home-made)enabler,this is much like a CFW without some features and its not permanent this means its gone after a hard reboot(taking out the battery or completly shutting down the system)
XMB-CrossMediaBar your PSP menus
PANDORA battery-a modified battery that allows you to put your PSP in service mode and do wathever you want with it its used for unbricking,downgrading and installing CFW.
BRICK-Its when you mess with your system software and damage it,its called flashing,its called a BRICK since your PSP becomes useless as a brick.
2.)PSP 1000 (FAT/PHAT)
This is wath it looks like:
ANY PSP 1000 is hackble
Ways of hacking:
1.You can use a Pandora Battery that you have to buy
*how to use a Pandora Battery:after you buy a Pandora and a MMS(Magic Memory Stick) insert them in your PSP and you shoud see a menu with CFW you have on your MMS.
2.)CFW or HENs depending on your firmware you can use CFW or HEN without pandora.
PSP 2000 with non V3 MOTHERBOARDS:SAME as PSP 1000
PSP 2000v3/3000/Go:
maxim615_2.jpg3000
maxim615_3.jpgGo
1.)On the 2000 and 03g 3000 you can have LightCFW or HEN
on 4g 3000 and GO you can have only HENs
CFWs:5.03 GEN,6.35 PRO-B,5.50 GEN
HENs:6.20 TN HEN
LINKS: http://www.psp-hacks.com/file/2052 6.35 PRO-B
http://www.psp-hacks.com/file/2046 6.20 TN-C
http://www.psp-hacks.com/2009/12/15/psp-custom-firmware-5-50-gen-d3-and-5-03-gen-c-for-hen-released/ 5.50 and 5.03 GEN
on Mar 01, 2011 | Video Game Consoles & Games
Tip
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
on Mar 10, 2010 | Video Game Consoles & Games
My psp 2001 don't have an iso folder its version is 6.20
Did you update the firmware? If you did then you have removed the custom firmware (CFW) and replaced it with Sony's offical firmware (OFW). If this is the case then you will need to put back on the CFW, as far as I know the only way to do this is with a magic memory stick and a pandora battery.
If you havn't done anything to the firmware then all you need to do is go to the root of the memory stick and add a new folder and name it "ISO"
Regards,
SOD69
Jan 31, 2010 | Sony PlayStation Portable (PSP) Slim...
Tip
Pandora's Ultimate Magic Stick 3.80M33-5
New version of UPMSv3 - universal PSP Unbricker/Downgrader/Upgrader, also known as Pandora's Ultimate Magic Stick, Now work with DC ver4 (Dark_AleX’s), for installing CFw 3.80M33-5 and creating memory stick into a “Ultimate Magic Stick” for use with “Pandora’s battery” (jigkick). Works for both PSP, Slim and/or Fat, and 1 stick for all functions for Unbricker/Downgrader tools. Also available is the “UPMS_v3.pdf Guide” to help you get started and usage.
The Ultimate Pandora’s Magic Stick is the simple solution to easily accomplish any of the following:
  • Recover any bricked PSP (Fat or Slim) and install sony firmware or CFw M33.
  • Upgrade Fat-Slims PSP to CFw 3.80M33-5, with 1.50 kernel patch-Fat Only.
  • Upgrade Fat-Slims PSP to CFw 3.71 M33-2, with 1.50 kernel patch-2 -Fat Only.
  • Update to 3.71M33-4 are installed to the ‘GAME’ folder from the XMB.
  • Downgrade Fat PSP to Fw 1.50.
  • Upgrade Fat PSP straight to CFw 3.52M33 from Extended Boot Menu then install update 3.52 M33-4 from XMB, without need to downgrade to 1.50.
  • Boot up PSP using Ultimate Loader with support for choosing which Pandora’s you reach V1, V3 or V4.
  • Boot up PSP to XMB with UPMS inserted-Fat Only.
  • Boot up to a full FW 1.50 from Memory Stick-Fat Only.
  • Use PSP Filer and other tools (If it requires 1.50, can’t for Slims).
Note: This software is free, and comes with no warranty. Despite it has been tested and it has worked, there is some risk with any PSP operation that involves flashing, so please try this at your own risk!.
Only Memory Stick "Pro Duo" are compatible. Memory Stick Duo are not supported. Read more... for installation
here.!
on Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
I have a psp with software 6.20 i add software to get cfw and a umd dumper and the psp says that the data is corrupeted how do i fix it
that is a (your firmware is a official firmeware)you cannot run any software like umd dumper you shoud have custom firmware if you want custom firmware if you a fat or slim and light psp you aree in luck you can make or buy a pandora kit and downgrade from any firmware if you are using psp go u cannot have psp custom firmware although the dark alex(creator of m33)is finding a way to make custom firmware in psp go and if you have psp slim and brite you cannot make the custom firmware yourself you may consider giving it to a game store for custom firmware thanks rate 4 thumbs i helped you naa
Nov 26, 2009 | Sony PlayStation Portable (PSP) Slim...
Pandora Deluxe sub for Pandora Batt
hi no you still need the memory stick and battery along with a custom firmware psp to make the Pandora battery .
i am unsure about the psp 2000 slim , from what i can find the Pandora battery should work but check for some other opinions first.
Aug 27, 2009 | Sony PlayStation Portable (PSP) Slim...
OFW 5.51 screwed me
a pandoras battery is just a battery that puts your psp in to sevice mode so that you can restore from bad firmware updates which is used with a memory card containing firmware official or not.
with out the service mode battery and firmware memory card i dont think you can install custom firmware.
what psp do you have the problem with?
you can find one on Google or here:
https://www.bargainpile.net/product_info.php?products_id=81&osCsid=kik8inpdmaf2m1ul5aj4t2or81
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
Games,Update, Version 5.02
The firmware/software 5.02 is official sony firmware, its can't load/play your iso game from your MS.. to load iso, You'll need install custom firmware on your psp, the latest cfw update is 5.00m33-3, You can find it by googling or see at my blog here!. how to create pandora - magic stick.
To change your psp from official firmware you'll need pandora - magic stick (latest update DC7 - 4.01m33)for downgrading and install cfw,because since high kernel released, cfwcan be installing from 1.50 OF fat(old model) psp.. and 3.60 for slimpsp as startingpoint.
When you have 4.01M33 you can update to the latest CFw 5.00M33-3.
Hopefully this help, Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 25, 2008 | Sony PlayStation Portable (PSP) Slim...
Sony PlayStation Portable (PSP) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
