Question about Toshiba Computers & Internet
My Toshiba satelite pro a 200 laptop doesn't want to charge the baterry when i plug it into socket. It happened once before few days ago and without any reason it startet to work again. Now it's been few hours already and it still doesn't wanna start chargin. The batery is totaly empty at the moment, so I cannot use my laptop. What should I do about it? Is there any possibility to check by myself what's the problem? should I exchange the charger? if yes, can I do it due to my warranty?cheers\\
  • Toshiba Master
  • 19,396 Answers
If the battery is out of charge, and the computer does not start at all, then you need to replace the AC adapter.
Here you find prices:
Toshiba Satellite Pro A200 AC Adapter $64.79 - LaptopTraveller.com Toshiba Satellite Pro A200 15 TO 24 Volt 120 ... $74.58 - BatteryFuel Toshiba Satellite Pro A200 AC Adapter $67.95 - dsmiller.com
Posted on Oct 10, 2008
Pressing the power button results in the power light flashing 5 times and nothing else happens
I would firstly remove the power source and battery, then remove the RAM and hard drive. Plug in the power source without the battery and press power. If it springs into life, remove the power, refit RAM and try again. If OK remove power and fit hard drive.
Dec 31, 2013 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My laptop won't charge
What do u mean by "adjust the cord" ? If u have to adjust by twisting the jack in the power input port then it is neither the fault of the cord nor the of the battery but may be the fault of the power input port.
Go to Toshiba service center and they will solv the prob.
May 23, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
Hi I am having toshiba satelite a 135
I would suggest the following:
Step 1: Press the DEL key to get into BIOS while boot-up.
Step 2: Select the option where it says "Load default settings"
Step 3: save and exit BIOS
After doing so, if you are able to boot your computer, then a new CMOS battery would be required to solve the issue for ever. This problem could also happen, if you haven't used you computer for quite long.
Mar 19, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba megf10 wont turn on
Formatin it could help but It will delete everything but once again it could be that your mp3 is mest up   REPLLY IF YOU NEED MORE INFO
Sep 11, 2009 | Audio Players & Recorders
Charging issues with a toshiba A215
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 11, 2009 | Toshiba Satellite A215-S7422 Notebook
Can I use a DC adapter on my new Toshiba Satelite laptop for travel. If I can what kind is best.
Your power adapter is most likely a multi voltage adapter. Check the label on the bottom of the adapter, probably 110-240V. If so all you need is an international mains adapter plug so you can plug the power adapter into the mains socket in a foreign country.
Aug 24, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
My satelite r15-s829 tablet laptop battery went aprox 10 days without a charge while shut off. Saturday I received a new ac adaptor, upon plugging it into the laptop an amber light in plug in icon on the...
This appears to be a problem with the ac charger its saying that ur charger is underpowered and cannot charge ur laptop take a look at ur older charger and buy the same brand and that should help out its a common problem that pops up for some that replace failed chargers
Dec 15, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
348 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
