Question about Epson Stylus C86 InkJet Printer
Epson printer deleted but still shows files on computer
I have changed my printer and deleted the epson but I still have files in my control panal abouy the epson when I rty to uninstal it states that they are not there . how do I get rid of these
  • 193 Answers
Go to new programs listing. epson listing..delete the printer by following the instructions
Posted on Oct 19, 2008
Computer cant detect the printer
Go to C:/windows/inf and look for files called oemXX.inf oemXX.pnf.
Open the .inf files one by one and look for the EPSON label in them and when you find one just delete the .inf and .pnf file equivalent. There might be more than one EPSON files in the inf library.
Then unplug the printer, restart the computer, and the add wizard should pop again when you replug the printer.
Hope this helps.
Jun 21, 2011 | Epson TMT70 TMT70 C31C637001 Printer
Tip
Epson Printers - Slow Printing Under Vista & Windows 7
I had been trying to resolve a slow printing problem for months. The client had an Epson printer and a Windows 7 iCore duo computer that slowed down to and absolute crawl while printing photographs.
Nothing seemed to work. Not clearing the drives of temporary files, or updating the drivers.
Then I ran a program called Process Monitor. I kept seeing the SPLWOW64.exe spike the CPU usage to 100%. The file it was processing was an Epson file called EPAUDF01.AUD.
After updating the Progam used for printing to a 64 it version, SPLWOWO64 went to 34%, but the system was still taking three minutes for each step of the printing process, loading, selecting size and selecting orientation.
When I did a search online under the Epson file name, I found out that this file is a temporary audit file and should be removed.
"Epson printers create an audit file called EPAUDF01.AUD in C:\ProgramData\Epson\Printer."
Once the file was deleted, printing was fast again.
Each time the printer is used, this file is created, but, it doesn't slow down. Somehow the old audit file got stuck in this folder and gummed up the works.
If your Epson is printing slow, fimd this file and delete it.
I created a shortcut to the folder on the desktop "just in case".
on Apr 16, 2010 | Office Equipment & Supplies
When installing my epson printer the following message appears 'File Epson E_DMA130.DLL is needed'.
Thank you for visiting Fixya.
One of the software files may be corrupt. Follow these steps to correct the problem:
  1. Disconnect the USB cable from your printer.
  2. Click Start and select My Computer.
  3. Double-click the icon that represents your hard drive (usually C:).
  4. Double-click Program Files.
  5. Double-click EPSON.
  6. Double-click PrinterDriverTemp.
  7. Delete the PMATEDX folder.
  8. (Confirm delete as needed)
  9. Reinstall the software using either the CD or the file you downloaded.
    If you reinstall using the CD and it still doesn’t work, repeat this procedure from step 1 but try reinstalling with the downloaded file instead.
Reconnect the USB cable when prompted to do so.
If the steps above don’t solve the problem, follow these steps:
  1. If you have any USB devices other than your printer connected to your computer, disconnect them.
  2. Click Start and select Control Panel.
  3. Double-click Printers and Faxes.
  4. Double-click Add Printer.
  5. Click Next.
  6. Select Local printer attached to this computer and make sure the Automatically detect and install my Plug and Play printer box is not checked. Then click Next.
  7. Select USB001 (Virtual printer port for USB) from the Use the following port list. Then click Next.
  8. When you see the window containing the list of manufacturers, click Have Disk.
  9. Click Browse, navigate to the C:\Program Files\EPSON\PrinterDriverTemp\PMATEDX folder, and then double-click E_DF19TA.INF.
  10. Click OK.
  11. Click Next or Finish in each remaining window to complete the installation.
If you see a window asking if you want to replace the existing driver, select, 'Replace Existing Driver' before you click next.
Reconnect your other USB devices if necessary.
Jan 28, 2010 | Epson Office Equipment & Supplies
Everytime scanner option is selected an error message pops up
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED.
Please follow the instructions below to help resolve this.
  1. Go to My Computer, by right-clicking the Start button. Select Explore
  2. Double-click the C: drive, then navigate to the following folders or location on the hard drive: C:\Documents and Settings\%username%\Application Data\EPSON\ESCNDV\ES00XX (where XX is any numbers or letters)
  3. Look for a BMP file or any file in this location and delete this file OR FILES THAT ARE .BMP.
  4. , can be xxxxx.BMP ( where xxxxx is the name)
Note::
  1. %username% above stands for your PC username.
  2. The Application Data folder is hidden by default, to un-hide this folder do the following in your Windows Explorer window go to the Tools pull down menu and select Folder Options
    Click on the View tab, look for Hidden files and folders.
    Select Show hidden files and folders option
    Click OK.
    you should now be able to see the Application Data folder continue in to the folder path above.
    (You may have to follow the steps again to turn off the Show hidden files and folders feature. )
  3. Removal and reinstallation of Epson SCAN does not clear out this file.
Jan 15, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
Language
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Jul 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ink Levels not showing
try uninstalling the driver from add and remove program: epson printer software.
and we need to completely trash epson files on yur computer:
**printer should be directly hook up on your computer via USB if its on a network status monitor will not actually show up:
**is this the only epson printer that you have on your system? if it is then we can go ahead and delete registry info:
Now we need to remove specific references to the product in the registry.
1. Click on START, then RUN.
2. In the RUN window, type in REGEDIT and press OK.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look at the column on the left.
9. Click on the “+” sign next to HKEY_CURRENT_USER
10. Click on the “+” sign next to SOFTWARE
11. Click on the “+” sign next to Epson
12. Click on the “+” sign next to PRINTER
13. If you see a reference to your printer's model, right click and delete it.
14. Click on the “-“ signs next to PRINTER, EPSON, SOFTWARE, HKEY_CURRENT_USER to close up this branch.
15. Click on the “+” sign next to HKEY_LOCAL_MACHINE
16. Click on the “+” sign next to SOFTWARE
17. Click on the “+” sign next to EPSON
18. Look for a folder with the name of your printer model. Right click on it and Delete it (if you don’t see it, then don’t worry about it).
19. Scroll down and look for a folder named PRINTER and click on the “+” sign to the left of it.
20. Look for a reference to your printer model. Right Click on it and delete it.
21. Click on the “-“ signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to close up this branch.
22. Close the registry editor.
reinstall driver from epson website: support.epson.com
Apr 03, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson stylus dx7450
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Mar 16, 2008 | Office Equipment & Supplies
Epson stylus photo R360
I had the same problem and so contacted Epson support. This was the reply, it worked for me.
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab. Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Find the files labelled OEMxx.inf, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says "SEIKO EPSON" or "EPSON" within the first few lines, then you need to close the file, and then delete it. Repeat this until all EPSON INF files are removed.
Step Three:
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinXP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Oct 08, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus C60 InkJet Printer will not print
First  go to your pc and click on file, print when the window opens does it show your printer in there? is it set to THAT printer?  does it show as being Ready?
If not re download the driver,  then click on File, Print, right click on your printer and set as default.
Next double click on My Computer, ( or click on Start, Control panel, printers and faxes, put your mouse over your printer it should say Ready, if not then change the cable
Sep 20, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
