Question about LaCie (300728U) 250 GB Hard Drive
My hdd beeps can i fix or data recov poss
Dropped hdd now it wont recognise and beeps once every 20 sec
  • freddy_flynt Oct 10, 2008
    thanx ginko i go to hdd doctor cant live without sample for music cheers mate.....freddy
  • 45 Answers
THATS RIGHT IF THE DRV IS MAKING THAT SOUND AND LIGHT BLINKING OFTEN, IT IS A CLEAR SYMPTOM THAT HARDWARE FAILED.
Posted on Oct 10, 2008
  • LaCie Master
  • 19,396 Answers
When it beeps it means there is a motor failure.
Data can usually be recovered but is expensive.
The disk need to be opened in a facility called "clean room" if you open an hard drive in a normal environment, the smaller dust in the air will ruin the data inside forever.
This kind of service costs no less than $800.
See an example here:
Recovering data from hard disk drives with motor failure ...
How to recover data from transcend hdd when not appearing in disk management and not showing under my computer. system detects it first with clicking sound but after sometime error appears as device d
Use hirens boot disc look for programme in hard disc tools called test disk.it will check and repair mft which should then allow the drive to be seen and then fix errors.failing that route try and get spin right which will fix bad blocks.
Sep 08, 2014 | Transcend Storejet 25m2 500 Gb External...
Buffalo ministation
first off take the caddy apart so you are don to the internal HDD once you have that connect it to either your PC or a friends PC that has the same connections on the motherboard, either IDE or ATA.
once connected look in my computer and check disk management (to get to disk management right click my computer and go to manage)
if you can see your drive in here then it is just your caddy that is broken simply buy a new one and put in.
if you can see the drive but cant access it try file recovery programs like recurrva or file inspector.
if you still cant see it unplug the orginal HDD and boot to a live CD/USB something like Knoppix and try to recover data
Jan 09, 2014 | Computers & Internet
Crashed external HDD Verbatim
Hard drives are easily damaged by dropping them.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 15, 2012 | Computers & Internet
Seagate 2 tb external hard drive beeps and clicks
Hard drives are easily damaged when dropped. The clicking noise is known as "The click of death".
This hard drive cannot be fixed. You need a new one.
If you need to recover data from this hard drive, then there are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Aug 23, 2012 | Computers & Internet
My external hard drive was damaged i wont recovery from hard drive.
Depending on the severity of the damage you have a couple of options.
1) Put the HDD inside a airtight bag and place in a freezer for at least 4 hours. Remove the HDD from freezer and see if it works. If it does start to work you will have a limited amount of time to recover the data.
2) Pay Data recovery company to recover the data
http://www.ontrackdatarecovery.com/
Mar 06, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Blinking light, clicking sound?
Hard disks clicking is not a good thing. Did you drop it?
Open the case and check connections.
If you can, install it as a slave drive on another machine and attempt to recover data from there.
Afterwards check the drive for errors, reformat and delete partitions. If it is damaged then parts of it could be used as storage, but I'd advise against using it as a bootable disk and as a storage location for precious data.
Failing this, there are specialists who can recover data from corrupted drives. You'd have to speak to them about it.
Hope this helps
Wheal :)
Mar 01, 2010 | Computers & Internet
Can i format sata hdd without loseing my files
partition magic may do it, but chances are not. in order to change a filesystem, you have to erase all data to avoid compatibility issues. some file systems have file size limits or even file name character limits and doing a format without erasing the data can corrupt the drive to the point where the data is unable to be recovered. I always recommend backing up data first and would never even try a format without backing it up.
Jun 10, 2009 | Fanner MASSCOOL 3.5" PATA and SATA hard...
DROPPED and BEEPING
Remove and reattach the HDD from Casing once and check it. If this wont work HDD may damaged. Consult MAXTOR customer service.
Mar 25, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Dropped hdd beeps wont be reconised by computer
What kind of beep is that? Anything similar to these sounds: http://datacent.com/hard_drive_sounds.php ?
Most likely the spindle got stuck. That's really bad.
Oct 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Data recovery from nono working hdd
All your files are still stored on the hard drive.They're just invisible or inaccessible.You can recover them with data recovery software.
http://www.asoftech.com/adr/
Dec 14, 2007 | Computers & Internet
LaCie (300728U) 250 GB Hard Drive Logo
395 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
