Question about Epson Stylus C62 InkJet Printer
Paper won't feed through the printer
When I try to print, the paper is grabbed by the printer and only moves into the printer 1/2 inch and stops.
  • Gerry Millward
    Gerry Millward May 11, 2010
    It's a long time now without any help forthcoming on this problem. Can you post a new comment updating the situation, so that I can try and help you fix it, or close it as solved!
  • 353 Answers
I think we can say the poster has solved this problem!
Posted on Mar 13, 2009
After a paper jam which I released by pulling from the front (bad, I know), my HP deskjet 3520 printer has stopped grabbing the paper and won't feed. Its wheels just spin like rapid fire once, twice, and...
You could try the following:
1.Unplug the printer and remove the paper tray.
2. Move the carriage all the way to the right.
3. Close the lid and plug the printer back in.
Wait until printer stop to cycle.
4. Open the lid. Carriage should return to nomal position.
5. Close lid and try printing again.
Feb 03, 2011 | HP DeskJet 3520 InkJet Printer
Paper feed won't work
Sorry no solution but I have exactly the same problem. I have tried everything mentioned in the on-line solutions. Is this problem fixable or is a service required? Thanks to anyone who can help.
May 05, 2010 | HP Officejet J5780 All-In-One InkJet...
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
Small photo paper
have you set up the paper size in the printer options when you press print, as it should pop up in a window before the print whre you click ok, asking what quality and size paper, but if you don't tell it it will assume that you are using standard A4 or whatever your standard paper size is.
May 27, 2007 | HP Photosmart 7450 InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Epson Stylus C62 InkJet Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
