Question about LG Flatron L1750S 17" LCD Monitor
Monitor has power; shows analog for split second; then goes black
I have taken the video cable to get checked out; and it does work. (At least Best Buy told me that it did work when they tested it) The power cable works because obviously it has power. I inserted an antivirus disk in the drive and tried powering up the monitor to see if it came up; this didn't work either.
    Champion:
  • 293 Answers
Hi...there,
Well...It's seems you got a busted backlight inverter. You need to replaced a new one or repaired it...
Posted on Dec 06, 2008
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
The monitor shows black when I power up my computer in the morning. When I turn the monitor off, then on, I get a picture for a few seconds with analog in the upper right corner, then it goes black again....
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 09, 2010 | ViewSonic VX1935wm LCD Monitor
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
When I power up my PC and monitor, the screen comes on for a couple of seconds, then it goes black
this happens with a few monitors and some graphics cards. if you connect your monitor through a DVI cable, try connecting it through an analog cable. if possible change your graphics card, that should solve it completely.
Jul 01, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
70 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
