Question about Dishwashers
I have a Bosch SHV55M03GB dishwasher which does not heat the water. The programme cycle also sticks at the last minute. Any ideas, heater element or control panel? Thanks.
  • 19,396 Answers
If cycle proceed normally after waiting for a while, then the control is probably OK. It stands by a while because it does not read correct temperature before proceeding.
If the appliance is connected to both hot and cold water, open more the hot water faucet.
If the water is not heating at all, check heating element for continuity, using a tester.
If water is heating regularly, but cycle is still slow, check thermic sensor.
Here are more suggestions from Repairclinic:
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
If you need replacement parts or exploded views you find them here.
Posted on Oct 10, 2008
Bosch classixx 1200 express sticking on 1 minute. Not heating water,so extending run cycle.Have checked ntc and heater, both ok. Does the wiring from heater element go to pressure switch?
Add water to increase water height, and hence increase the pressure to the pressure switch, if it's not blocked with soap debris it should tell the programmer that it has water, and allow the heater to turn on.
Aug 20, 2016 | Bosch Washing Machines
What is cold resistance of heater element? Bosch SGS56E02GB
If the heater element had infinite resistance, it would be defective. Possibly a defective thermostat.
Jul 01, 2015 | Bosch Dishwashers
Where is the thermostat located on a SHV55M03GB
Exact location can be traced from the wiring to the heating element which is shown in spread diagram of a dishwasher. check this link:
Mar 11, 2012 | Bosch 24 in. SHV55M03GB Built-In...
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
Bosch dishwasher SHX46A -cycle runs too long (4 hours)- items still wet. The economy cycle also runs too long - should be about 80 minutes and it ran for 200 minutes.
It sounds like there's a problem with the dishwasher's heating element. The dishwasher uses the heating element to heat the water to certain temperatures, and it will wait (run for extra time) for the water to reach this temperature, and may eventually give up. When it's time to dry, the dishwasher uses the heating element to steam dry the dishes. If you're not technically savvy, you will probably need to have a pro work on the machine, but first check to make sure there's not hard water scale buildup on the heating element. If you're brave enough to work on the machine, you should check to see if the element's plugged in, check its resistance to make sure it conducts electricity, check the element's switching components, and finally the dw's computer board. There's a chance that the machine is just stuck in a loop or something. You should try turning off the circuit for a few minutes. There's a chance it may reset and start working.
Dec 07, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Doesn't get hot and steamy especially during rinse cycle
Try whispering sweet-nothings into its ear and kissing it. This always gets me "hot and steamy". ha, ha
But seriously, the steam you see in your dishwasher is created when the heating element inside the dishwasher heats the water up even higher than your water heater. This provides extra cleaning power. The heating element is also turned on during the drying cycle to help dry the dishes quickly. That is why you get a blast of steam when you open the door at the end of its cycle.
So no steam means either the element is bad (likely) or the controller/timer is bad (hopefully not, $$). If you know how to use an ohmmeter then you can "ohm out" the element and see if it is open (unplug the power first!!). If not, you can remove the element and take it to your parts store and ask them to do it (again, turn off the power first!!!).
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
Dishwashers Logo
373 people viewed this question
Top Dishwashers Experts
