Question about LG Shine KE970 Cellular Phone
LG shine wont charge
My LG shine has gone dead and my wall charger and my usb wont charge the batter, i even borrowed my friends charger and it still doesnt work, i think it might be my phone where the charger connects. ??? plz help?
  • Anonymous Oct 13, 2008
    Almost same problem - have gone through 3 wall chargers - however will charge with car or usb charger.
Yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Posted on Mar 05, 2009
I have the same problem I even replace the battery with a new one and still dead ,no charge , I tried the car charger and the house charger and still wont charge. any suggestions
thx
Posted on May 22, 2010
Yea thanks so much man i cant believe it worked. so simple. Thanx jus2sik
Posted on Sep 15, 2009
Wont power on
1. Your charger has failed.You could borrow a same charger from a friend to see if the problem continues.
If problem persists...
2.Motherboard is dead..and i think this should be the most possible in tou case.
Mar 27, 2014 | Acer Cromia Chromebook PC Notebook
Battery wont charge
Please check the battery charger. Otherwise, I had one of this HP Mini 1000 replaced by HP with the same problem, the Mini gone complete dead, no charging or turn on.
Apr 07, 2012 | HP Mini 1000 Netbook
My lg shine died bought a new battery that has been charging for 17 hrs still nothing
It could be your charger. Even though charger light is on it maybe defective. Can you put in another phone or borrow one and/or charger from a friend?
May 27, 2011 | LG VX5200 Cellular Phone
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Env1 will not charge
that was such a great phone. have you tried to borrow a batter from the local providers store? if it works that way then all you need to do is buy one
May 04, 2009 | LG enV VX9900 Cellular Phone
My LG shine cu720 will not charge?
my phone stopped charger and i went to settings and usb connection and go to music sync and then i put it on the charger and played with it for a lil while then it started charging and every since that i never went dead!!
Jan 31, 2009 | LG Shine KE970 Cellular Phone
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Not turning on LG SHINE KE970
I have the same problem too! And i just don't know what happend or something. And I do not have the manual anymore
Jan 10, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
1,392 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
