Question about HP Office Equipment & Supplies
On setup for HP Photosmart c5200 printer, I received an error message after installing the black ink cart#74 which was included in box at purchase. error"cartridge in slot onright is not intended for use in this printer" cannot not proceed with setup
My Printer is new and I had a problem with Setup. I cannot believe that HP wants to charge
me for inquiring about the defect. I will pack the printer up and return it to the store I
bought it from and never buy HP again.
Posted on Oct 12, 2008
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
My hp photosmart all in one printer c4480 keeps saying incompatible print cartridge when its the right cartridge and its full of ink and reseting it isnt working. it was working before and now it just...
Hy. I have found a different solution for c4480 "incopatible cartrige". it worked for me so i hope it works for you to
Steps:
1. Press X+power at the same time
2. Press BLUE, GREEN, GRAY
3. press BLUE until you see "INFORMATION MENU"
4. press OK
5. Press Blue until you see "CHECKSUM FOR RELOCK DATA INPUT"
6. OK
7. Press X until you exit all menius
8. When promted for aliement cancel it with X.
It should bypass the error
Dec 14, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Keep getting this message incompatible ink cartridge on my hp photosmart c4480 all in one printer, helppppp
Hp knows about your issues you can read the forum here, Currently there working on a critical update.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Incompatible-Cartridges-after-Critical-Update-HP-Photosmart/td-p/107505
Let me know ether way we are here to help. Please do not forget to leave a rating before you go, thanks
Aug 10, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Put new cartridge in officejet j6410 and overnight it now says cartridge on left needs replacing. put old cartridge back in and it still says the same thing
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
Dec 26, 2009 | HP Officejet J6410 All-in-one InkJet...
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
Oct 03, 2009 | HP Office Equipment & Supplies
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
May 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
Incompatible Ink Cartridge notice with proper HP ink
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74 / 75 (or 74XL/75XL) cartridge(s) are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
Dec 12, 2008 | HP Photosmart C4280 All-in-One InkJet...
Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
Dec 03, 2008 | HP DeskJet 5150 InkJet Printer
112 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
