Question about HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro l7500
Horizontal lines appear on the picture
lafalot
  • 152 Answers
SOURCE: i cannot install my new
Have you checked in Device Manager to see if there are any conflicts? If not, check your Printers folder and see what is listed. If the HP is there, delete it, reboot your machine and see if you can reinstall the driver. Let me know how it goes.
Posted on Aug 22, 2008
  • 52 Answers
SOURCE: Horizontal pink & blue lines across color pictures that I print.
In the past when I have seen this on my old printers, it is the color cartridge. Eithe the haed is cloged or it needs to be replaced. You could try to take the color cartridge and set the print head(copper colored end) on a damp towel for a little while and see if it will release the clog. (HP uses mostly water base inks and they dry out sometimes) Then wipe the head on a dry cloth. Reinstall and try again. You should also have software for HP to prime the head and clean it. Try that and if you still have problem, replace color cartridge.
Posted on Mar 04, 2009
SOURCE: HP Officejet Pro L7500 -
Had a similar problem " with my L7590 allin one unit, "scanner did not function" from the Solution center. If your unit is plugged into a surge protector, unplug the unit from the surge protector and plug directly into the wall power socket. It solved my problem. Can you believe this.The explanation is that the printer goes into sleep mode it reduces the amount of power needed for its uses and the internal surge protector of the unit notes this; however, when you "wake the printer up" the difference in power usage between the two levels may be considered by the surge protector as a power surge and limit or halt the increase, disabling certain functions. George
Posted on Apr 15, 2009
SOURCE: HP OfficeJet Pro l7500 won't print. Printer queu
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Posted on Aug 11, 2009
SOURCE: NowLaunching=X:\HPZdUi01.exe-|XXX-fX:\DIViNS??.dat
Try the following: first start the installation until the error rises - don't continue. Then change to the "normal" printer installation through system/printers/add printer There install a local printer at "HP Standard TCP/IP Port" ("Standard TCP/IP Port" works too), fill in the ip, choose HP and your printer - it now should be listet due to the interrupted installation - finish this installation. The printer is now ready. At last terminate the waiting (exe)installation by taskmanager - don't let it finish cause it tries to deinstall the printer again. Regards Erik Nagel
Posted on Nov 13, 2009
My HP officejet pro 8600 has horizontal line when i print magazine from ipad. Help plz.
Try calibrating the line feed. Or you may have to clean the print heads.
Aug 06, 2013 | HP Officejet Pro 8600
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
My officejet pro L7580 printer is printing horizontal black lines on my pictures. What can I do for this?
you more and likely would need new printheads, this particular printer is one of the worst HP ever produced. i have these in the shop weekly.
Nov 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When printing photos, black lines appear.
Have you tried cleaning the heads? it should tell you how to in the manual.
Aug 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
I have officejet pro L7500, and i cant send a fax
put two pauses after the phone number then the extension
Jul 04, 2009 | Office Equipment & Supplies
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Jun 10, 2009 | HP Office Equipment & Supplies
Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Dec 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
HP Officejet Pro L7680 All-In-One Printer Logo
Ben Johnson
