Question about Magellan Meridian Gold GPS Receiver
No serial output suddenly from my Gold
I've been using my Magellan Gold for the last 3 years on my bicycle, mounted on a homemade bracket in front of the handlebars and connected through a serial cable that ports my GPS positions via the radio to a web page http://aprs.fi/?call=w5aox-6&mt=m&z=11&timerange=10800
This is a rugged environment, but it worked fine until recently, when my GPS still visibly works fine, display, etc, but will NOT seemingly send data through the cable. It's not the cable, as I have two and neither work. It seems intermittent; very occasionally it will work for a few seconds and then stop again. I assume it's something rattled loose inside or a cracked solder joint. I took it apart and checked the wiring to the data connector. The ends connected to the circuit board were a bit frayed from vibration so I removed, trimmed, and resoldered them, with no improvement.
I'd love to know if there is a repair manual available somewhere? I am able to work with the surface mount electronics inside.
HamGPSbiker
    Problem Solver:
  • 5 Answers
If you carefully open the GPS you will see that that serial contacts are simply wired to the motherboard. It could be as you say and a joint cracked.
To open it, there are 6 screws, 2 on the outside, and 4 inside the battery compartment. DO NOT screw with too much force, you might break the simple plactic that they mate to.
When you open the unit, be careful to not dislodge the o-ring. So hold your GPS level with the back side UP.
A little solder should fix your problem.
Posted on Feb 26, 2009
  • 3 Answers
If i remember right you can test the GPS units serial port at power up.
1. Press and Hold "OUT" button then press "PWR"
2. Follow units onscreen directions.
you may need to have serial cable connected to COM port to verify transmission
good luck
Posted on Nov 02, 2008
I have a vintage road bike with the serial number 2940058 that is stamped beneath the bottom bracket. I have not had any luck locating the type of bike which my cousin gave to me.
A bike is not "vintage" just because it's old, and ID'ing by serial number, especially one that is all numbers, is not possible without more info. Please see my Tip for more guidance:
How to determine the year value etc of your bicycle
Nov 27, 2016 | Cycling
Where is the serial # located?
Usually under bottom bracket (crank housing) or on outside of left rear dropout. Front of head tube may have a date code. Serial number is not very helpful with bikes. How to determine the year value etc of your bicycle
May 15, 2016 | Cycling
I'm trying to find the serial # for my 20 year old Murray bike
Look on outside of left rear dropout (where the wheel slides in) or under the bottom bracket (crank housing). Not very useful or important - your Murray is not collectible at all, parts do not depend on model year, and hard to get any info from serial number on a department store bike. How to determine the year value etc of your bicycle
Serial # G42 4732 found on crank case
The serial number on underside of the bottom bracket is of little or no use. How to determine the year value etc of your bicycle
Apr 05, 2016 | Cycling
Date of manufacture of predator serial number 00583 schwinn
That is better, now we have something to go on :>)
http://re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Lots of info
  • Schwinn Serial Numbers and Date Codes - Re-Cycle re-cycle.com/History/Schwinn/SwnB_Serial.aspx Schwinn Serial number and date code ... Schwinn Serial Numbers and Date ... out the crankset to check for a date code. If you have a Schwinn from ...
  • Schwinn Serial Number Info - BMXmuseum.com Forums bmxmuseum.com/forums/viewtopic.php?id=18201
    • LAST UPDATED: 2013-05-10
    • 51 POSTS
    • FIRST POST: 2007-06-28
    Schwinn serial number sequences, ... separate date code number on the right rear fork end that ... I have a 1980 schwinn predator.
  • Schwinn serial number date codes - Angelfire www.angelfire.com/rant/allday101/SchwinnCodes1.html this chart applies to chicago schwinn`s only. scroll down for the date codes links ... if the serial numbers are found on the left rear dropout
  • Determine the Manufacturing Date waterfordbikes.com/w/culture/paramount/paramount-dating Determine the Manufacturing Date. ... Schwinn would add another digit, ... serial number 018524. All Paramount tandem production had ceased by the end of 1979.
  • Schwinn Lightweight Data Book (Serial Numbers) schwinnbikeforum.com/SLDB/serial.htm Serial Numbers Chicago built Schwinn Serial Numbers for the ... a letter representing the month of manufacture, a number indicating the last ... Schwinn Date Codes ...
  • Schwinn serial number lookup tool schwinncruisers.com/serial-number.html Vintage Schwinn serial number lookup. Enter your Schwinn serial number in the box and click "find" to see what date and year your Schwinn ... Schwinn serial numbers ...
  • Bike serial numbers https://bikeindex.org/serials Serial numbers All bikes 1 all have unique serial numbers. Most bicycles have their serial number engraved beneath their bottom bracket, but sometimes serial numbers ...
  • How to Date Schwinn Bicycles ' eHow www.ehow.com > Hobbies, Games & Toys > Hobbies > Antiquing How to Date Schwinn Bicycles. The Schwinn Bicycle Co. is an American bicycle company and a ... For Schwinn's the serial number location has moved to ...
  • Nov 10, 2015 | Schwinn Cycling
    Need help finding a bike serial number
    Bike serial numbers are located in different places on the bike. Some are below the handlebars on the frame, some are on the center post, some are under the crank, some are on the rear mounting brackets. The best suggestion is to keep looking, its there somewhere
    Oct 08, 2014 | Cycling
    Bottom bracket size
    Typical mountain bicycles are 73mm, though modern (in the last 5 or so years) some have been going to 68mm. You can measure the bottom bracket shell. That is the part of the frame where the bottom bracket is inside. Measure from edge to edge without including the cups of the bottom bracket itself.
    Apr 06, 2014 | Raleigh M80
    Bicycle serial number
    try this search: https://duckduckgo.com/?q=bicycle+dating+codes
    If it's a potential Raliegh I recommend this: http://sheldonbrown.com/retroraleighs/dating.html
    Mar 23, 2014 | Cycling
    Replaced front engine mount on Nissan Quest 3 times in the last year. Any idea what is causing mounts to go bad? Don't tell me it's how I drive.
    Nissan quest has a huge proble. I searched with google and many others to fidn this same problem. The over drive can cause the torque to slowly break the cheap motor mounts. If you replaced it yourself you know how cheap and weak they look. There are mroe expensive brands with lifetime warranties in which they last a good 4-5 years even with a lead foot aka my wife slamming on the gas everywhere lol. So look to a more expensive motor mount with a lifetime warranty. When someoen guarantees it for life they build it not to break :) sorry for spelling errors im on a tablet. Im havign a bundle of trouble with my quest, the vcr built in stopped working, blower motor went out replace fsu and blower switch in dash and next up is blower motor. Have fun nissan quest are great vahicles, cheap parts but a hell of a time diagnosing the problem. Good thing is its about 50 bux for a life time warranty front motor mount. A way to help stabilize it i did when racing is put a heavy duty chain around the bracket as well, wont hurt a thing and will save the life of your motor mount. Sounds rigged but works like a charm. I had to change a motor mount on my mustang form racing 1 time a month untill I put the chain on there with the new one.
    Aug 16, 2012 | 2001 Nissan Quest
    I have a Fat Boy Lo with a vibration in the front at about 45 mph. It has 300 miles on it. I've had it back to HD 3 times now and it still is not fixed. The last attempt they changed the front tir
    Hi Anonymous, and the usual suspects are:
    1. Wheels and or tires unbalanced, worn or damaged.
    2. Engine/transmission/vehicle not aligned properly.
    3. Primary chain badly worn or links tight as a result of insufficient lubrication or misalignment.
    4. Engine to transmission mounting bolts loose.
    5. Upper engine mounting bracket loose.
    6. Ignition timing incorrect/poorly tuned engine
    7. Internal engine problem/ flywheel shift runout should be .003" max.
    8. Broken frame
    Good luck and have nice day.
    Jul 13, 2012 | Harley Davidson Motorcycles
    Magellan Meridian Gold GPS Receiver Logo
    96 people viewed this question
    Top Magellan GPS Experts
    Will Halftowaite
    Are you a Magellan GPS Expert? Answer questions, earn points and help others
