Question about Whirlpool GEW9200L Electric Dryer
Whirlpool le5800xkno wont start after running fine last night, i can only here the timer ticking but the start button wont activate the dryer in any mode. i have checked all wiring and the element to see if any wires were disconnected or burnt, and the breaker is fine as well. any ideas?
  • Anonymous Dec 01, 2008
    Doesn't start, can hear normal humming noise when set to a cycle.
    Genius:
  • 1,122 Answers
Have you checked the door switch?they do get stuck or go bad ,let me know what you find-mike
Posted on Oct 10, 2008
  • 750 Answers
Did you turn the machine off for 5 minutes and then restart it to see if it resets the system?
My whirlpool estate dryer just stopped running about 5 min after I started it. Checked outlet that is fine. Door switch fine. Timer ticks.
Is the inside of the drum very hot. My guess is over limit thermostat is reporting overheat. Check for lint build up in hoses or even birds nests.
Oct 03, 2015 | Whirlpool Dryers
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
When dryer is started the timer can be heard and if the door switch is activated, the heating element will heat, but the drive motor does nothing. belt is ok
try holding the door button, have someone push the start button and you spin the tub at the same time. If it starts, it is most likely the start capacitor on the motor. If it does not start, look at door button, start switch/button, and lastly, the timer.
May 01, 2010 | Whirlpool ET8CHEXSQ Dryer
Whirlpool LEQ8000JQ - My timer ticks but the dryer will not run when start button is push.
More specifically, the timer can be heard running, starts and stops when door is closed/opened, so not likely to be the timer. You have a problem at the motor. A wire off a terminal, the switch on the motor, or the motor itself.
Nov 29, 2009 | Whirlpool LEQ8000JQ Electric Dryer
I have a Whirlpool Comfort Plus II Gas Dryer that when you press the start button, it will not start. I was running last night but when my daughter went to start on a new load of clothes, the dryer would...
Try the door switch and see if it clicks to activate. Also, make sure that the dial is always turned clockwise so as to not strip the teeth. Could be the timer .
Jul 05, 2009 | Dryers
Whirlpool Dryer won't run.
Tremal fuse. $21. Thanks for the help. Lance
Apr 01, 2009 | Whirlpool Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Whirlpool dryer
Yes it can at times. It has been my experience. This thing may be falling apart on the inside. Just replace it before it gives you further problem. There is more heat and resistance there at the contacts. While you are replacing it, check the other things as well. It seems like you have a good eye for this anyway.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool GEW9200L Electric Dryer Logo
267 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
