Question about HP Office Equipment & Supplies
How do I make the print out text larger on my HP deskjet (F2187) printer and scanner. it is sooooo small I cant read it.
    Genius:
  • 1,011 Answers
Dear,
did u check the setting in print page setup..
if not then try with that..
by the way, the page that u r going to print, does it seems of normal size..
select the A4 page in page setup and select proper margin and check the font size as mensioned above..
regards,
hope it will fix your problem, so dont forget to rate it
Posted on Oct 10, 2008
How to enlarge words when to print is too small too read ?
Copy text to a word document. Then select all then change font size, then print. Then make an appointment to have your eyes checked.
Dec 28, 2014 | HP Deskjet 3050 All-in-One Printer CH376A...
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
How print sideways hp 3512 ?
If you are using annotative text, it may be one of the settings with your text style. Type STYLE and select the style that you are using.
There is a check box for annotative text (it shoudl be checked) and directly under it is another one that aligns or rotate the text with the viewport. Uncheck this option. otherwise reinstall the driver. HP Deskjet 3512 Printer Driver Download For Windows 78 1XP
Jul 21, 2014 | HP Deskjet 3512 Inkjet Multifunction...
The print is too small to read so is there a way to enlarge the print without loosing the text that runs off the page?
Set the printer properties to default and also see if the paper setting is A4 or which is default inserted for printing.. you will get results... Good Luck.
Jan 07, 2011 | HP Deskjet F340 All-In-One InkJet Printer
All text is too small. How do I print in a larger test?
CHANGE THE FONT SETTINGS WHATEVER THE TEXT YOU ARE GOING TO PRINT
Mar 09, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
HP Deskjet 6980 Printer. prints on half page
you'll need to reset the print mode to single-sided, also check the print/text size
Oct 25, 2009 | HP Office Equipment & Supplies
Printing so small hard to read. HP 932c Email prints at normal size. It's just very small when printing from the internet. Thanks,
look at your perfences before u print the letter. change the font to a larger size. the web browser that u are using has perferences that print at a certain size font..
Jul 15, 2009 | HP DeskJet 932c InkJet Printer
E-mails print too small to read. New printer does same
Try placing you cursor on the text that you would like to print, hold the control key down then tap the PLUS key on the numerical pad a few times.
This should make your fonts larger so that they may print normally.
Jun 20, 2009 | HP Photosmart C7280 Printer
How do you make print size larger on hp office jet v40
When you bring up your directions in mapquest, under the red "MapQuest" logo in the upper lefthand corner there are these options:
prt-btn.png Print Save Send To Click on the "Print" option and a printer-friendly version will appear. You can choose "text and map" or "text only," then click on print and your printer options box will appear. I hope this helps.
Jan 04, 2009 | HP OfficeJet V40xi InkJet Printer
I have a c4200 hp Printer cc200-90006 i need to know how to get the printing larger.Can't read my bankstatements to small when I try to copy.
Make sure you have the proper drivers installed for the printer, then cut and paste the information into a word processor or similar that accomidates the desired print format.
Finally, change the text size and print.
The issue is not with the printer, but the program you are using to facilitate the print job. If this is a web based program, look for a "Printer Friendly" print option on the site.
Alternately, you may have limited success in changing the text size under "View" in your browser, and try printing with the larger text size selected, and in use. If truncating occurs in the printing, then you will have to cut and paste the text into a manageable format, like a Word Processor program.
Nov 19, 2008 | HP Office Equipment & Supplies
102 people viewed this question
Seeker5211
Seeker5211
