Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
MAYTAG JETCLEAN QUIET PACK
HI THIE LITTLE WHITE PIECE THAT IS IN THE MIDDLE OF THE LOWER ARMS HAS BROKEN OFF. WHAT DO I DO? THANKS RITA
    Genius:
  • 1,239 Answers
Hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Posted on Oct 10, 2008
My maytag dishwasher jetclean quiet pack won't drain
Hi Cherie: Try watching this video that demonstrates how to repair non-draining dishwashers: https://www.youtube.com/watch?v=rO19zoOyNHA
Apr 18, 2015 | Maytag Dishwashers
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
My Maytag MDB6000AWW is leaving a heavy white film. Mostly on the cups and the dishes in on outside, although this may not be relevant. The arms on the top and bottom are clear and seem to be spinning,...
Yes,
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Maytag 24 in. MDB5600A Jetclean II...
I have a maytag jetclean quiet pack dishwasher. The top dishes are not getting clean. The glasses always have sandy residue in them and sometimes orange juice etc at the bottom of the glass isn't removed....
Possible that the pump is not working well to spray and inject with good pressure so that the dishes are spot clean.
You will need to simulate the washer without any dish and checck the performance to understand the fault areas.
The middle section also must spray well another reason your dishes are not clean when kept low.
The entire system has to be taken out and the water flow sections must be cleaned. the pump must work and spray with high pressure or else it must be clogged , the reason for sluggish spray.
So check the inlets, the water lines and the pump.
The rest sems fine.
Sep 02, 2010 | Maytag Dishwashers
Maytag spiner arm removal
Most of them just pull down and off. the little plastic jigger that holds them often breaks, so I would order a new one first before forcing it...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " Great tips, will get the handy husband on this asap........thanks " -
Apr 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Dec 20, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
881 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
