Question about Dryers
My hotpoint condenser dryer keeps tripping the trip switch
  • wanno12 Mar 09, 2009
    My hotpiont condensor keeps tripping the trip switch.
    Genius:
  • 1,239 Answers
HI The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
Posted on Oct 10, 2008
  • Dryers Master
  • 19,396 Answers
Replace the switch, or the whole control/timer assembly.
If it keeps giving you troubles after replacement, you will need to check the electronic control module (small box) inside the appliance.
Insert model number here to get schematics and replacement parts.
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Posted on Jan 19, 2010
SOURCE: Our Hotpoint ctd00 keeps tripping the fusebox, we
you need to clean out the ALL the fluff from the back of the dryer and dry the electrics and element(i use a hair dryer~)!! There is a small opening at the very bottom that gets blocked and water backs-up onto the element and electrics
Posted on Apr 24, 2010
Condensed dryer keeps tripping out my electric when I turn it on
Disconnect from mains. Remove rear panel and water will probably come out. This water is being flung by the fan onto the heater hence tripping the electric.
cause of water being here is a blockage in the condenser stopping flow into water chamber or possibly but unlikely, failure of the pump
Oct 11, 2014 | Hotpoint Aquarius WD640 Front Load...
My hot point condenser dryer keeps tripping the trip switch, have changed fuse but still not working
This would tend to indicate a problem with the temperature sensor not switching off the heatercircuit so it overheats and then trips. As soon as it cools down the machine will continue to work OK. This shouldbe a very quick and cheap repair.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 07, 2012 | Hotpoint Ultima Tc71n Condenser Dryer...
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, my hotpoint wdm73 washer dryer keeps tripping
Remove the top cover, and unplug the motor, and try again, if it still trips, then disconnect the heater element.
If it still trips, then I recommend you all an engineer.
Jan 25, 2010 | Hotpoint Dryers
Dryer tripping RCD
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius tdc32 condenser dryer keeps cutting/tripping out after 5 minutes usage. Press the start button immediately after and won't start. Have to give it 10 minutes or so before starts up....
It may be necessary to clean the condenser unit/module (heat exchanger). Often lint would accumulate reducing the efficiency of the condenser causing the temperature internally to rise above specs. Thermal cutoff senses and trips the unit.
In some instances, it could be the thermal sensor/thermostat. I think your particular model has two of them. To gain access inside, it would be required to remove 2~3 panelings. A continuity tester is needed to check the thermostats.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
Dryers Logo
483 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
