Question about LG DLG5932W Gas Dryer
How do I remove a roller
I have an LG DLG5932W dryer. It started making squeaking noises a couple of says ago and stopped working. I managed to open up the dryer using the service manual and found that two rollers had just seized. One of them is in such a bad shape that two sides of the roller are flat.
I'm having trouble removing these rollers. Can someone please tell me how I can do so without breaking the assembly. Should I be using a wrench or is it simpler than that?
Thanks,
MT
    Genius:
  • 1,239 Answers
Hi
The front of the dryer's drum is usually supported by two rollers. These wheels are either metal with a rubber rim or pressed nylon. If the rollers squeak but appear to be in good condition, apply a few drops of 20-weight nondetergent motor oil (not all-purpose oil) to them. If the rollers are worn, you can replace them if the roller assembly is not riveted. To replace drum rollers:
Step 1: Remove the front of the cabinet. Rollers are usually held on a metal shaft by a spring clip.
Step 2: Remove the rollers by prying the spring clip off with a screwdriver. Under the clip are a washer, the rollers, and another washer. You might have to remove a small nut at the back of the shaft and remove the shaft itself to reach the rollers. Remove the rollers from the shaft and clean away built-up lint and dirt before installing the new roller. This dirt and lint buildup could cause the drum to turn slowly, which prevents proper drying and strains other dryer components.
Step 3: Install the new rollers on the shaft with the washers in the same position.
Posted on Oct 10, 2008
Drum makes noise when turning
You have 2 wheels the drum turns on replace these they look like small roller blade wheels they are located in behind the front door at the near bottom and it requires 2 of these rollers one on the left one on the right. Thanks they may cost 20 30 bucks for both. Remember to rate my solution and give testimonial this is how i earn my achievements here on FixYa Thanks in advance
Apr 26, 2012 | LG DLG5932W Gas Dryer
Push start button makes noise squeak for a couple of seconds and then the noise stops dryer otherwise runs fine.
drum rollers,drum glides or belt idler assembly, all these items can be found on eBay. note the routing of the belt, the idler assemblage is next to the motor. this website shows the rollers/glidesand how to open the dryer, hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Nov 27, 2010 | Dryers
LG Gas dryer has started to make weird screechy(?) noise - almost like the drum is rubbing against something. It's a couple years old - is this a maintenance thing or will I need to replace?
You will need to have the unit checked out by a qualified LG tech to diagnose your problem. Sounds like one of the roller guides may need to be replaced.
Good luck
Sep 23, 2010 | LG DLG5932W Gas Dryer
My dryerr is making a noise like rattle I know nothing about dryers but maybe a belt or motor?? I have an electric dryer. .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 13, 2010 | LG DLG5932W Gas Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
Did you resolve your dryer / noise?
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Makes squeaking noise after running for about 10 minutes
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
LG DLG5932W Gas Dryer Logo
343 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
