Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel degx1 electric clothes dryer
Wow, what a piece of junk! Had a repair person out yesterday, didn't even take out a screwdriver, just hooked his computer up to my dryer and told me I would need a new heating element--- $75 for yesterday's call and $300. for parts and labor when he returns, what a joke, 3 years of service for a $800. machine. Here's the problem, If I push the reset button the dryer works, I have cleaned out all the lint, any and everywhere, these dryers get lint in every nook and cranny! The dryer heats up, but then somewhere along the way gets about 1/2 way through the cycle and shuts off?
I think the thermosat is not regulating properly~ I refuse to call another service man out, where can I get parts myself? Oh by the way, I called a Paykel recommended service agent out, he finally agreed, I should get a new dryer, and this time~ not a Fisher Paykel. Now there's some advice from someone who works on them!!!!
  • 1 more comment
  • ktyler44 Nov 12, 2008
    I have had the same problem for awhile now. I recently talked to an appliance store manager who is familiar with the problem, and he said it is a known problem. He suggested calling Fisher & Paykel because they have developed a kit to fix this problem. I did that, but since I can't provide documentation that I have had my dryer serviced before, they won't help me. The store where I bought my dryer has since gone out of business and they would have had any and all documentation of the service. I'll never buy Fisher & Paykel again.
  • James Harris Dec 07, 2008
    We have had our Fisher Paykel DEGX1 for 3 years and it has worked fine until today. Now it is making a weird screaching noise as if a bearing is bad. Is there anything I can do rather than pay a technician $400?
  • Anonymous Feb 03, 2009
    My dryer turned itself on and got really hot. What can I check?
    Genius:
  • 1,239 Answers
Thermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2:
 If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Posted on Oct 10, 2008
Fisher and Paykel top loading dryer is squeaking and leaving black spots ( which are easily removed by rewashing ) on clothing. Please help!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 19, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
How can i reset an electric dryer fisher & paykel it runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel dryer does not dry properly. I have to run 2 cylces to make the clothes dry
If you have to run the dryer 2 to 3 times as long to dry the clothes then you just need to make sure the vent hose behind the dryer isn't kinked up and the vent is open all the way out side ,,, that will fix it for you.
Larry
Nov 25, 2008 | Fisher and Paykel DEGX1 Electric Dryer
FISHER PAYKEL DRYER
there is a reset button located inside the front panel on the dryer. Try pushing it.
Jul 14, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
973 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
