Question about Onkyo Audio Players & Recorders
When playing a dolby true hd soundtrack my Onkyo 875 makes a clicking sound every so often like it has run out of buffer memery for the sound. Any help you could give me would be great Thanks
  • 4,234 Answers
What you are hearing is digital noise that can have many sources. One thing that would help to narrow this down is to try and see a pattern of when the clicking occurs. Is is all the time, or just after the unit has been on for a while? Does the clicking vary with the type of sound? Soft/loud/vocal/music etc?
Thanks,
Dan
Posted on Oct 10, 2008
How adapt audio from 43 inch hd tv with no headphone jack to vivanco fms 2000 speakers
follow the chart troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Televison & Video
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
True HD - biggest secret
Are you playing a TrueHD format disc? Just like DTS 5.1 or any other format if your disc isnt coded in TRUEHD then your not going to get it. DTS or other formats cannot be "converted" to TrueHD like the video portion of a standard def disc. At this point there arent alot of TrueHD discs out but be paitent, this may change. Or not, due to the fact there are other "lossless" formats that may be more widely adopted. Sort of like DTS and THX were when DVD first came out. Hope this helps.
Mar 31, 2008 | Onkyo TX-SR605 Receiver
105 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
