Question about O2 Xda Orbit Smartphone
How do I stop the GPS searching automatically
My 02 Xda keeps searching for a connection automatically. Even when I disconnect, I switch the Xda onto standby and as soon as I switch on it is already connected or trying to connect. It is costing me a lot of money being connected to the internet when I'm not actually using it.
  • recker152 Oct 14, 2008
    The solution was helpful in that it pointed me in the right direction, but I was hoping to get a solution without going in that direction, as it was my ISP who gave me the settings in the first place, and obviously did'nt mention about having a manual setting rather than an automatic setting.
  • 2,035 Answers
You need to contact the service provider and get your GPS setting from automatic to manual to avoid the gps getting connected..And check if your mobile as a navigation software installed on it ,if yes then it will try to net all the time ...
Good luck...
Posted on Oct 13, 2008
  • 1,952 Answers
Reset ur setting and try
to perform a hard reset
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the lower left
2. Release the stylus, but continue pressing the two soft key buttons.
Release them only when you see the following message on your
device screen:
“Press Send to restore manufacturer default, or press other keys to
3. Press send on your device.
I want to increase my Android 2.1 LG GT540 phone battery performance.
Here are some tips to increase the performance:
1) Run a lower brightness setting on your screen. Make sure it's not set to automatic. 2) Don't run widgets that update all the time. The more your data connection is running, the more power you use. 3) Make sure screen is turned off when not actually using the phone. 4) If you're in range of WiFi (like at home) use WiFi instead of cell data. It uses less power. 5) Don't have your WiFi, GPS, or Bluetooth on when you're not connected to them. It takes a lot of power for them to continuously search for a connection. 6) Run less background syncing. If you can get away with your email syncing only once every 15 minutes, do that instead of it syncing continuously. 7) Search your phone model on XDA Developers to find additional tips.
8) Last one. Don't run Automatic Task Killers. They often times shut down needed background services which requires a higher CPU load to restart. More CPU load means more battery usage.
Mar 06, 2011 | Cell Phones
I want to install driver of my 02 xda11 to my computer
You can choose these addresses to get your O2 Xda IIs driver :
Dec 24, 2010 | O2 Xda IIs Pocket PC
Fix brake switch on a 1997 chevy tahoe
Stop Lamp Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  3. Using snap ring pliers, remove pushrod retainer from brake pedal pin.
  4. Remove stop lamp switch from pushrod.
  5. Disconnect stop lamp switch electrical connector.
To Install:
  1. Connect stop lamp switch electrical connector.
  2. Snap stop lamp switch onto pushrod.
  3. Using an 11 mm socket, push pushrod retainer clip onto brake pedal pin.
  4. Connect battery negative cable.
  5. Arm the air bag system.
Aug 04, 2010 | Chevrolet Tahoe Cars & Trucks
60CSx switches automatically off directly after connect
Go to Main Menu by pressing MENU button twice. Choose SYSTEM and press ENTER. You can change various settings on this page. Make sure that for GPS option 'Normal' is selected. If it is set to 'Battery Saver Mode' the GPS will switch off after certain time.
Jul 07, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Does't connect to network - search Network
It sounds like you may have a poor 3G reception in your area. Even though other O2 phones are working better they may be running on the 2G masts in your area.
Try in setting/network menu turning off 3G reception, that way the device will only look for 2G masts. Your handset will give priority to 3G masts where available and sometimes will hold onto the weakest signal making poor call quality, and or dropping connection.
Advantages to using 2G only = better standby and talk time / better reception where 3G is poor.
Disadvantages = Slower web browsing / no video calls.
WEP / WPA will only apply if you are connecting using WI FI and have nothing to do with your mobile network connection.
Hope that helps?
Apr 27, 2009 | O2 XDA Flame Smartphone
Mms gprs settings
ring o2 again and ask for a sim update, and a gprs install message, this will diagnose your problem
Nov 24, 2008 | O2 Xda Trion Smartphone
Because after you plug in your phone to your comp,it will automatic connect to the interner connection from your computer,that's y it will auto disconnect from other interner connection.
Nov 05, 2008 | O2 Xda Atom Exec Smartphone
Xda II - no sound/speaker
It may be speakers connector got removed from the board.
Jun 01, 2008 | O2 Xda II Smartphone
Why does my bluetooth keep turning itself off ON MY 02 XdaII this even happens when it is all fully charged.
I has the same situation like you but opposite event. My O2 XDA II or Siemens SX66 or even calls Qtek 9090 is another version with your O2 has sometime Bluetooth keeps turning on. I turn it off for few seconds, it is on again. I tried to solve th eproblem by get ito the setting area to turn it off and reset my PDA. My PDA has the area calls Wireless Manager. I click on all three function including phone, wi-fi, bluetooth and go out of wireless manager area and get into connection and click on Bluetooth and turn it on or off then only Bluetooth get effected. I don't know why but that is I found out my own way. Just play around these features by testing it the way I mentioned above. i hope this help. This feature is not stable in these type of models. You are not the only one. ALSO, TRY TO GET IT ON TO CONNECT WITH OTHER BLUETOOTH DEVICES TO HOW IT IS REACTED. Good Luck
Mar 29, 2007 | O2 Xda II Smartphone
Bluetooth GPS Tom Tom to operate with PDA Xda IIi
Have you tried using 'other wired device', try each com, rather than bluetooth, on tomtom configuration settings, works for me with TT5 and a Holux BT GPS reciever
Jan 28, 2007 | O2 Xda III
O2 Xda Orbit Smartphone Logo
57 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
