Question about Toshiba Satellite 1805-S204 Notebook
No boot laptop do not boot power light is on ac adapter is ok and batery also ok the computer most of the times dos not start not even the bios/setup but i can ear the cooling fan working but not the hd
  • sacur Oct 10, 2008
  • 82 Answers
The power supply could be faulty. typical voltage output are 3.3 V a5v and 12v.
You are probably missing one of these.
Power supply comes as a unit. Easy to replace.
Posted on Oct 10, 2008
Contact to this email adresses;debasishpanigrahi5@gmail.com
insert the bootable disk then if it cant boot contact above email adresse
process for solving the problem:
insert bootable disk that is ur dos xp or vista disk
then the screen will display press any key to boot from cd/dvd
press any key
then format ur hdd and install fresh new os
imp:dont use piracy . piracy also one of the cause of this problem
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
My laptop was shut down, then when I was start it again it doesnt work anymore...What should I do?..please help me, aside from this those keyboards does not functioning correctly in their corresponding...
First thing you do to power your laptop on again try removing the battery and the charger complitly leave it for 10 sec without power then press the on off switch for 2 or 3 times without puting the power or batery later try not to put the battery and put only the power adapter and start your laptop dose it starts if yes good shut it down and put the batery in and start the laptop if its starting and leave it running for cuppul of hours and then again remove the power adapter and let it run the system with batery power if it stays on and fine you are ok and fine there was just a power dump but if it fails in any case like fails to boot with power adapter and so you have adapter issue need to be checked if dosent work with batery it self its a batery issue and needs replacement .
regarding the keyboard issue you can open the kay board and clean it with contact spray if posible.
Dec 12, 2010 | LG NB E500-JAP51A Notebook
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
Hard drive will not boot.
try to install with other sytems and check the data cable
Jul 11, 2009 | Acer Aspire One PC Notebook
Unable to charge my battery on Dell 510m
can you plzz be more specific , you have an issue with the batery charging , but you are able to turn the system on with the AC adapter connected to the laptop.
you can try updating the BIOS of your computer from the website support.dell.com also restore defaults in the system setup...
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Evo N410c- Won't boot
can you go to the bios info? if yes check the time if that is rong change the inetrnal batery and loock for the hd and the boot order set to 1st hd than save that and see what does now if you can not go to bios so you have to check the batery and the ac adapter
Dec 26, 2007 | Compaq Evo N410C Notebook
Toshiba Satellite 1805-S204 Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
