Question about Denon AVR 2808Ci Receiver
Help required for dumbo on Amps Denon AVR 2808CI
Hi! this is my first purchase of any kind of amp. I purchased Denon AVR 2808Ci in USA and moved into India and conected it will stepdown voltage covertor 220 v to 110 v (100watts). But with out any connection I tried to powere on the amp and to my suprise I could see that only the power (green light) but I couldnt see any display in the front display panel. I would like to know that is the front panel display shows only if I make all the connection or its a defect amp I got.
Think i got ur problem. you have mentioned that you used a stepdown voltage covertor 220 v to 110 v (100watts). But Denon 2808CI model which you bought from U.S needs 110V (500watts peak power). so try running the amp with a 220V to 110V (500watts or more) and im sure it will work.
Posted on Oct 25, 2008
  • 142 Answers
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
Posted on Oct 10, 2008
I mistakenly gave 220volts to my DENON 2808CI. There was a burning smell and denon is no powering up. What must have burned? i opend th etop lid and checked eveyrthing is fine except th epower transformer...
fuses only fail from excessive current and not wrong voltage
take it in for a proper diagnosis but with twice the required voltage , the results will be --junk it and next time used the correct adaptor for the voltage
May 25, 2017 | Denon AVR 2808Ci Receiver
How to change fuses on denon 2808ci played it loud
Sorry to read about your problem, I hope this helps you out.
you will need to take off the covers, and replace the pop out fuse's
Look around, where the power wires come in.. they look like clear class with metal on each end or white cerramic..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Denon AVR 2808Ci Receiver
Moved receiver ... smelled like burning rubber ... now only red flashing light comes on and it doesn't turn on completely. Did it blow a fuse? Can it be repaired?
sounds like something shorted it out yes it cn be repaired you might be able to find another unit on ebay for the same price it would cost to fix it
Dec 05, 2009 | Denon AVR 2808Ci Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at
May 09, 2009 | Denon AVR 2808Ci Receiver
AVR 2808 CI remote does not recognize back speakers.
perhaps that's why it was returned...Take it back for a replacement.
Apr 01, 2009 | Denon AVR 2808Ci Receiver
Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
Nov 12, 2008 | Denon AVR 2808Ci Receiver
Lost audio for no apparent reason
Try unplugging your HDMI cable from the AVR I would like to see if your AVR is trying to use HDMI out instead of the composite. Next try plugging each device directly into your television, this will isolate the issue and tell us for sure whether or not it's the AVR.
Jul 10, 2008 | Denon AVR 2808Ci Receiver
Denon AVR 2808Ci Receiver Logo
343 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
