Question about Toshiba P25-S526 Notebook
USB devices not detected
I have the Toshiba P25 S526, I'm trying to use my external dvd drive to be use as the first boot device for reformatting my system, I updated the BIOS 2.10V (I think it is) but it doesn't detect the drive and actually the screen freezes on booting and I have to disconnect the drive only then it will continue to boot up, can you advise???
    Genius:
  • Toshiba Master
  • 1,250 Answers
Go to the bios and check the boot device order, if the option for usb boot is there makes it first, ortherwise make cd/dvd as your first boot device, ........... enable all the usb options available on your bios
Posted on Oct 10, 2008
Toshiba P25 cannot read cd
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Toshiba Satellite P25-S5093 Notebook
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
How do i replace harddisk in my toshiba p25 s487
Ensure you have your backups up to date and either OS disc or rescue discs to place a new system on your new hard drive.
Remove the larger cover from the underside of the laptop, slide out the hard drive. Remove the old drive from the cradle and fit the new drive to the cradle. Slide it in.
Power the laptop up open the DVD drive and place your restore/PS disc in it and on the bios menu select F12. Set the boot device to DVD/CD.
Boot from the DVD/CD drive and follow the prompts.
When finished, download updated drivers from www.toshiba.co. and restore your backups and programmes.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite P25-S487 Notebook
Mouse pad on laptop not working after install of new hard drive and os. usb ports also not working.... any ideas as to what is going on inside there?
  • “Hi, “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the "Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver, "Update Drivers, click Apply and (OK).
    Note: Restarting the computer will configure system changes.
    "Rating the solution is your way of letting me know if it (helped or not), thanks."
May 05, 2010 | Toshiba P25-S526 Notebook
Toshiba m45-s355 reformat from usb
Hi
Thak you for yor query
To ensure the CD/DVD is clean please try booting from a known working PC, from what you are describing it may not be your CD drive
If the same thing happnes on another PC then it is the CD/DVD that is faulty, however if it works, then you can try to hook up a external drive, the laptop may defualt to it after trying all the other options i.e. CD rom drive, HDD etc
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If this has been useful please leave positive feedback/vote/Testimonial - it will be highly appreciated
Feb 12, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
Windows 7 on Toshiba P25-S526 PC and there drivers
For any drivers not automatically installed with Windows 7 running Windows Update should detect most all of them. You should make sure to select all updates, including optional updates (not the language packs). The optional updates may include hardware updates which will ensure your hardware is using the best and most current software possible. If this does not detect everything, I would recommend going to the toshiba support website and downloading the remainder of the drivers from there. You should also make sure your laptop is compatible with Windows 7 by checking out Windows 7 Upgrade Advisor.
Good Luck,
NOLA Tech
Jan 31, 2010 | Toshiba P25-S526 Notebook
Toshiba satellite p25 s5093. won't boot.
The system cannot find your hard drive so it is trying to boot from the next device which is thinks is a network drive. Check the attachment of the hard drive, sometimes they can come loose from the interface. Remove the hard drive and place it back. If the machine still cannot read the drive, try another hard drive to see if the drive is the problem or is it a problem with the interface. Make sure to remove any discs from the cd/dvd players and make sure no usb network adapters are in it while booting. Check the boot order again.
Jan 29, 2010 | Computers & Internet
Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Jan 09, 2009 | Toshiba Satellite P15-S420 Notebook
Toshiba P30 - I can't complete the reformat/restore operation
pull out the cd drive and reboot. then go to programs folder and un install any new dvd or cd programs that where just installed. reboot . then try to install your drives again
Nov 17, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba P25-S526 Notebook Logo
220 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
