Turned 42inc plasma tv off at plug and it banged at the back of the tv ith a smell of burning and will not work now
  • 4,234 Answers
Most likely a capacitor has been damaged. Is this set still under warranty? If so, please request warranty service. The power supply module may need to be replaced. If you can post the ,ake and model number, I can get you the part number and cost if not under warranty.
Thanks,
Dan
Posted on Oct 10, 2008
Need code for 7 blonks on power button
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
www.info.com/panasonic_viera/plasma/tv/th42pz80u/blinks/7_times/and/black/screen/mean/
most likely failure of module in the tv, most likely fuse, capacitor, something burn up, find the air vents smell the area your smelling something burn up smell, if you have every smell electronic stuff burning up you will understand what i mean you will never forget that smell.
Oct 06, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
I have a 2006 LG 42PC3DV Plasma TV and everytime I try and turn it on it makes a double clicking sound and then turn back off..any reason why?
try to test the relay,, or maybe the capcitor, diodes in power source section with your multi tester,, and i think, there is a thermostat beside power that leaks or defective maybe,, then try to change it..
Jul 28, 2012 | LG 42PC3D 42 in. Plasma Television
Sony ke-32ts2u plasma tv went bang, blueish flash, turned off, then back on.. I smelled burning, so unplugged immediately, and went looking for obvious signs of something fried or melted. No sign, so I...
I doubt there is an easy fix but your situation suggest that you have a bad ground on that outlet and a short in the tv tried to go to ground through your cable itself. Plug in an "outlet analyzer" to both outlets. They are under $10US at supply stores such as Lowes and Home Depot. Through a combination of lights, it will report the status of the outlet
What you described is a failure in the power supply circuits for your display. You would need a wiring diagram and expertise. internal exchangeable fuses are rare anymore. They are usually a set of diodes which must be desoldered.
Sep 17, 2017 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Heard two loud bangs now picture is dim and has black areas that go away when that part of turn ithe picture is light. when u turn it obn its all black and the slowly lightens up but still real dim
Sound like a defective z-sustain board. When looking at the back of set with back off its on the far right. It usually has a fuse which will also open when its defective.
Oct 17, 2010 | LG 50PC3D 50 in. Plasma Television
Loud bang, then audio only from my tv
YES YOUR YSUS PANNEL HAS JUST POPPED CHECK OUT EBAY FOR REPLACEMENT,,
6871QYH053B
IS THE MODEL BOARD U REQUIRE,,
THERE WAS A GUY ON EBAY 64.99 AND 12£ POSTAGE AS LONG AS YOU STILL HAVE SOUND AND NO PICTURE,, YOUR PSU SHOULD BE FINE,,
Feb 11, 2010 | LG 42PX5D 42 in. Plasma HDTV
My Sony plasma tv made a pop sound and now picture is dark.
You will need the y and x sustain boards replaced, possibly the buffers. very expensive repair. you can replace one board but its best to do all of them.
Jan 22, 2010 | Sony 50 in. Plasma TV
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
Jul 20, 2007 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
