Question about Zanussi Dishwashers
The machine is not taking any water in - Zanussi Dishwashers
  • Zanussi Master
  • 19,396 Answers
First check the water supplies at the back of the machine.
That is either a problem wit the inlet valve , or with the water level switch.
See the following suggestions from Repairclinic:
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Oct 10, 2008
Why Frigidare 22s750 Washing machine doesnt take in Water at all..Everything is connected. But washer not taking in water
Please check the pipe through which water goes in the machine, there could be a blockage or check for any buttons which block water inlet.
Aug 16, 2014 | Washing Machines
WMUD962p not taking water
Possible the filters in the inlet of your machine (top behind) are clogged. It is simple to clean out, refit carefully. Plug off the machine, unscrew the inlet water connection just behind machine to check fine filters. The water from your wall faucet should have good pressure.
If helped, pl click.
Apr 16, 2013 | Hotpoint Washing Machines
Not working no taking water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Machine does not take water. the water does not come in to the machine. I think it can be the water pump.
Before breaking into your machine, shut off your water inlet valve(s) to the machine. Remove your water inlet hoses from the machine and aim them into the wash tub or a bucket. Check water flow through hoses. Debris in water system can clog up the screens on your water hoses.
Aug 02, 2009 | Washing Machines
Candy C1 145, takes water and outputs it to drain
yes you can unplug the machine take the back off and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and one when you let the air out if so then clean out the steel or plastic pipe you took it from, it normally blocked with soap goo, replace the pipe and try the machine again eric
Jan 13, 2018 | Candy Washing Machines
Washing machine takes long during wash cycles and does not take hot water through red pipe .
check your water supply at the washer tap and your problem is fixed as the machine is taking so long because its heating cold water up
Jun 23, 2009 | Washing Machines
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
Mar 05, 2009 | Kenmore Washing Machines
Simpson 175 wont take on hot water
Your water inlet valve is bad on the hot water side and needs to be replaced. It is located right after the supply hose for the hot line behind the back plate
Feb 13, 2009 | Whirlpool Washing Machines
Dishwashers Logo
293 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
