Question about Refrigerators
  • tayloj15 Oct 10, 2008
    make/model LG FRIDGE/FREEZER GR409GPA white includes watercooler
  • 142 Answers
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
Posted on Oct 10, 2008
I have a Britannia nabraska side by side fridge freezer. All of a sudden the freezer compartment is not cold enough as though the door had been left open - but 24 hours later has not got colder
You may have a bad thermostat or you could just be frosted over inside. You'll need to look behind the back panel in the freezer for syntoms if unplugging to defrost doesn't work.
Mar 23, 2015 | Refrigerators
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
May 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
We recently moved to a house with a Bosch KGV28V01GB fridge freezer outside but it doesn't seem to be working. Its plugged in and the light comes on when the door is opened. The switch is set to ON but...
Good day,
Refrigerators are designed for indoor use only. The lowest temperature they will perform normally is 55 degrees.
As the temperature drops below that it degades to the point of not working at all.
P.S. If you move it inside, give it a 24 hour warm up period. The oil in the compressor will be too thick, and can even ruin itself trying.
Jan 01, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
531 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
