Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer is not printing and black cartridge has ink Black not printing, changed two cartridges but still no print. Contacted HP who will offer no help unless I use their extortionate phone support system. Three weeks out of warranty!
    Novelist:
    Scholar:
  • 111 Answers
Are there any error messages that display on the control panel of the printer or on your computer? That might narrow down the problem and the solution.
With what you have said so far, it could be a couple of things. The printer series you have tends to not print at all unless all of the print cartridges have ink in them. If even one of them is empty or near empty, printing seems to stop, even if you aren't going to print using the color that is empty. My first recommendation is for you to check all of the cartridges to make sure they all have ink in them. Replace any that might be empty.
This sort of issue can also be caused if the electrical contacts between an ink cartridge and the print carriage are dirty. Assuming all the cartridges have ink in them, you should check the electrical contacts on *both* the cartridges and the print carriage. HP.com has a web page that shows you how:
Cleaning Electrical Contacts
Go to Step Two in this document for the proper instructions.
If my suggestions don't solve the problem, please post back any other information that might help narrow this issue down. As I previously said, if an error message appears on the printer or computer, please post the exact text of the message. That will help a lot. Thanks.
Posted on Oct 10, 2008
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
My HP Photosmart D7360 will not print black, despite changing cartridge and performing print-head cleans
I have the same problem. I just re-installed all ink cartridges into my printer from the first actual cartridges given to me with the printer and the black ink doesn't work. I contacted HP and they told me that I needed to change my black ink, after I already told them that I have tried 2 new ink cartridges in the system. I went out and bought another one thinking that this would fix the problem, and it didn't. I contacted HP again and I was told that it was the printer that was broken. The actual black ink section was faulty. Since it was a year and a month since I bought the product it was not under warranty, so nothing could be done but to buy another faulty piece of merchandise from HP. I could also service it, but that was never given a price tag. If you want my opinion don't purchase anything from HP again, I know I won't.
Apr 22, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
112 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
