Question about Whirlpool LER5636P Electric Dryer
LER6636PW0 drum does not turn
The other day my boyfriend took the back off of the dryer to try and find his keys. They weren't there of course, but when he put it back together he didn't put all of the screws back in. I'm not sure if that had anything to do with it or not, but soon after when we tried to use the dryer the drum wouldn't turn. I decided to take it apart and see if i could figure it out. When I did I found one of the pulleys had fallen off somehow and was resting on the bottom. The belt is still intact and loosely resting around the drum, not attached to anything. I have found virtually nothing on the internet on the assembly of this model so if anyone could help me with putting this back together I'd really appreciate it.
  • fakestar Oct 10, 2008
    Is there any bigger versions of those pictures? They seem like they might help but I can't see them in the detail that I need.
  • 958 Answers
Hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.LER6636PW0 drum does not turn - 8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Posted on Oct 10, 2008
  • francis rivero Oct 11, 2008
    Here is the link where i got them. it can be magnified ....
    http://www.partselect.com/AdvancedModelS...
    tnx 4 using fixya
    drcool
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
I have a whirlppol ler6636pw0 I have no heat. I was going to try to change the heating element and heard it could be a thermal fuse as well. Is there another fuse on thes. Also is the heating element on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Whirlpool LER5636P Electric Dryer
The drum does not turn smoothly and makes a griding sound. I am trying to take the back panel off and took all the screws out but can not get the panel off.
drum roller/glides just click on open my dryers cabinet:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 17, 2011 | Dryers
After using the dryer, the next day there is water in the drum. This happen several times lately and now the dryer will not turn on.
Hello. I can help. Get back if this response does not set you on the right course and tell me whether your dryer is gas or electric.
Begin by unplugging and then pull the dryer out and disconnect the vent from the back of the dryer. I suspect that you will find a partial blockage in the rear of the dryer itself or in the vent pipe. Check the entire vent all the way to outdoors.
If you find anything get back and let me know. I will hang in there with you on this problem.
Jun 29, 2009 | Whirlpool Dryers
MOD T700 ASKO DRYER REPLACED DRUM ROLLERS PUT BACK TOGETHER WILL NOT TURN ON
When I took the back off my Asko to clean it out I had to lay it on its face to get the drum to line up again with the back - in the doing this a wire pulled off its setting. Did not figure this out until I took the top off the dryer and found the loose wire. I have no idea if this is your problem but it was very frustrating. There is also a black reset button on the back of the dryer that you might try.
Jun 15, 2009 | Asko T701 Electric Dryer
Dryer drum does not turn - only by hand?
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 10, 2009 | Dryers
The "fin" inside came off
if i remember right ..remove washer top remove hose or pug in top of outer tub rotate basket until fin is at top i believe you can acess screw through hole..of course i have been known to remember wrong and apologize if i have this time let me know
Aug 19, 2008 | Kenmore Elite 45986 Front Load Washer
Back of dryer
Always disconnect power
  • Kenmore,
    the Front comes off, the back is fixed and rigid.
  1. remove the lint screen
  2. remove the screws that hold the lint screen holder to the lid
  3. there are spring clips at the front corners that can be pressed in with a putty knife or other blunt blade to unlock the top cover.
  4. raise the top
  5. there are screws either side of the front, inside the case points to the front heads to the rear, remove them,
  6. unplug the door switch, lift front off drum and supports and away.
reassemble in reverse
easy access to drum to remove it and replace felt ring, rollers belts.
When you replpace the belt, you should check the felt bearing around the open end of the drum, and the pully/idler wheels as well.
Often the cause of the belt breaking is the extra force needed to turn the drum when the felt or rollers are fubar.
Aug 03, 2008 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
