Question about Consew 206RB
Thread keep breaking
I have a consew model 230 industrial plain machine and the cotton keep on breaking.
  • Kelvin Boone May 11, 2010
    Cotton is difficult to sew on these machines are you using industrial quality or the small household spools like they sell at Walmart?. Is your needle appropriate for the thread ?
    Problem Solver:
  • 11 Answers
It might be a burr on the point of the needle.
Posted on Dec 07, 2010
How to thread Consew Industrial Sewing Machine 206RB
Every machine is a little different, but the basics are the same. Our 7th grade Home Eco. teacher taught us the first day...
"...Start at the thread spool, thread guide, thread guide, tension, take up lever, thread guide, thread guide, needle. Learn this and you can thread any sewing machine"
she was right, As this hold true for my kenmore, juki, singer and new home machines. Same basics for industrial machines too.
Hope this helps.
Sep 16, 2012 | Consew 206RB5 Sewing Machine
Top thread keeps snapping on consew 230b
Top thread snapping. Do you have an idea of there it is breaking?
First I would check the needle throat plate and needle. If you have stab marks on your needle plate, examine it closely for a crack. (get out the magnifying glass or jewelers loop) I recently fixed a problem I had with an old singer that kept breaking the top thread by replacing the needle plate. The old needle plate was so damaged it had actually made a knife edge which consistently cut the thread right at that location.
Change your needle and make sure it is the proper size for your thread. Too narrow of an eye can shred the thread causing it to break.
Next, check anything along your threading process that could be catching or snagging the thread. A worn or chipped thread guide can be a real problem.
Also make sure your thread hasn't dropped down below your thread cones and wrapped around the thread spindle. This would cause extra tension that might not be readily apparent.
Good luck
Aug 15, 2012 | Consew Sewing Machines
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
I bought a consew 230 industrial machine, but when I try to sew on it the needle breaks. What do I need to check, the threading, needle or what?
make sure the needle is inserted correctly
check the needle clamp screw to make sure it's tight
the needle is to fine for the fabric being used
also make sure under the needle plate there is no lint
also in bobbin area
also check the tension
Nov 26, 2010 | Consew 206RB
Consew 230 machine, how to dis engage needle to wind bobbin.
I have an old Consew 230B and need an operating manual can any one help me. Thank you
Mar 19, 2010 | Consew Sewing Machines
Consew 230 continually breaks top thread at needle
What size thread are you using? With thicker fabrics, you should be using at least a size 50. Even a 30 would be better.
Oct 18, 2009 | Consew Sewing Machines
Consew 230 sewing machine...will not pick up bobber thread
needle should be 16x257 Industrial machine needle with no flat side.
It does have a long groove on one side and a scallop just above the eye of the needle on the other side. On this machine the needle is inserted so that the long groove goes to the left and it threads left to right.
The thread breakage may be caused by a rough place on the hook. You need to turn the machine on it's back and look and feel all the way around the hook assembly. If you find a rough spot it can be removed with an emery stick. If it's not a rough spot, then the machine is probably out of time.
sewman7
Mar 16, 2009 | Sewing Machines
Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Apr 27, 2008 | Consew 1118-3
Consew 206RB Logo
314 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
