Question about Sony Playstation 3 (PS3) Console
Ps3 remote i cant get the remote to pair with the ps3 can you help me please
  • Anonymous Jan 18, 2009
    I have a PS3 pse1000 wireless remote (psyclone essential) and threw out the instructions. Can you help?
I had the same problem. So i looked all over the package for instructions, then i saw a usb connector with a connect button on it. It was cleverly hiden in the package, i can see how you missed it
Posted on Feb 22, 2009
Which remote the controller or the remote to control the bluray and stuff. If its the controller just plug it to the ps3 with the usb cable then press the ps button. If it's the remote for the blu ray. I'm pretty sure you just have to go the the "Accessory Settings" and find the option to pair devices. Make sure the remote is in the mode where it searchs, check for that in the booklet, and there may even be a code you have to put in the ps3 (possibly '0000') or whatever it may say in the booklet.
Posted on Oct 11, 2008
3 Suggested Answers
urbanhookupz
  • 213 Answers
SOURCE: Cant pair ps3 wireless headset
sometimes it is easier just to watch a video!
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Pairing Problems:
  • If the PS3 cannot locate your headset, make sure that your headset is in pairing mode before you start scanning. The headset instructions will tell you how to set yours to pairing mode.
  • If your headset is missing from the device menu after you re-start your PS3, you will have to pair again. Many headsets will only "remember" one device at a time, so you may have to register again after using your headset with a phone.
  • If your headset appears on the Audio Device menu but is "grayed out" or not selectable, it is not connected. Make sure the headset is charged, and that it is on in standby. I should connect automatically when the Audio Device menu is selected. Tap the call button on the headset if it does not connect, or click on the Connect Bluetooth tab on screen.
  • Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
  • Most in-game voice chat drops are simply network lag. Usually they go away after a short time, so be patient. In extreme cases you may have to leave a game and return to reset the chat function.
  • If you use wireless internet, a low signal strength to your modem/router can make voice chat malfunction. Make sure your wireless signal is as strong as possible to your access point.
  • Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Posted on Apr 08, 2010
  • 24 Answers
SOURCE: how do i pair my Bluetooth remote with my PS3??? I
system software version 1.30 or later is required
if up to date then go to manage bluetooth devices and see if the remote is in there.
make sure the batteries are good in the remote
Posted on Jan 07, 2011
How do i pair my Bluetooth remote with my PS3??? I know how to get to the "scanning.... Please wait." screen, but i don't know which buttons to push on the remote to pair??/ Please help!
Jan 07, 2011 | Sony Blu-ray Remote for PlayStation 3
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
My ps3 is not pairing with my remote and when i hold start and enter down nothing happens
I solved this problem by taking the batteries out of the remote turning the power off the ps3 for 5 mins then put the batteries back and turned the power back on to the ps3 and went to the settings and paired it up sorted
Dec 19, 2009 | Sony Blu-ray Remote for PlayStation 3
Need instructions for my ps3 sony bluetooth bd remote
nope. go to the ps3 setting part and into accesory settings. press bd remote. and follow the prompts. it is that simple.please rate
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Just got a new ps3 and i dont no how to turn the bluetooth on
I'm pretty sure you can't just 'turn on the bluetooth', it doesn't work like that, well not for my PS3 anyway.
The controllers use bluetooth, if you want to turn them on just press the PS button on the controller, that will sync it with the PS3, thus making it usable.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
Does samsung wep250 headset work with ps3
Same here, except i cant seem to be able to pair the wep250. I Used it first with my phone and it worked, then i deleted it and disabled it off of my phone, now i cant seem to pair it with my ps3. :( Do u have any suggestions?
Jun 22, 2009 | Radio Communications
Bluetooth headset wont pair to pc
i fixed this problem by enter "0000" (four Zeros) as the passkey, it accepted it and it didnt ask me to enter the passkey on the remote device ie the headset ,which is handy as it doesnt have any number keys ;)
it then added the device and it stayed on teh "added devices" list!
hope this helps
Feb 18, 2009 | Sony Video Game Consoles & Games
Can't pair up my blu-ray remote with the PS3.
I had same trouble in the beginning.
I have 80G PS3 and tried pairing and also registering.
I solved it by taking out the batteries then going to the menu where it says Register Blu Ray remote (System 2.40 version) then put the batteries back in and you do as the instruction says => Press Start and Enter button at the same time for 10 seconds ... it will say it registered.
I just did it.
Dec 29, 2008 | Sony Blu-ray Remote for PlayStation 3
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
Sony Playstation 3 (PS3) Console Logo
239 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
