Question about Intel D865PERL Motherboard
About motherboard i have a intel D865perl mothrboard with intel prescot 533 processor, rescently when am working it has stuk monitor display , then i re start, problem solved, but then it's get stuk many times. now i cant work wt the matchine, bcoz when i boot th matchine, it's not woking for 5minites and stuck, then if i restart monitor does not give any display, it;s behave like stand by mode(only blinking the monitor light but cpu is runing), if i leave it for 15minutes and reboot, then it's boot like before and then stuk within 5mins. i want to know why this is happning?
  • 778 Answers
I believe you have overheating problem
Remove side of case and clean all fans including power supply one then clean and remove all fluff and dirt from Heat sink vanes.
Then vacuum out case include all vent holes and behind power supply ones
Then restart computer
Posted on Oct 11, 2008
I want know intel d 945gcr supports quied core processor or core 2 duo processor?
Support for the following:
Intel Core 2 Duo processor in an LGA775 socket with a 800 MHz system bus
Intel Pentium D processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Pentium 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Celeron D processor in an LGA775 socket with a 533 MHz system bus
Aug 14, 2014 | Computers & Internet
Remove fan d865perl
It depends. You usually must replace the entire heatsink/fan assembly. If you have the standard 'Intel' heatsink/fan that came with a retail boxed Intel processor, you flip the levers in opposite directions to loosen the assembly, and then you slip a thin piece of metal under each of the four hooks that attach it to the mobo, but you do them one at a time. You just pry a little bit and lift up on each one. After the last hook is freed, you pull the unit completely off the board.
There's also a power connector. Don't forget to unplug it. There are at least 100 different styles of HSF for that mobo. You also want to twist a little to work the thermal-transfer compound loose. Otherwise you might pull the processor out with the HSF.
Jul 05, 2012 | Intel Desktop Board D865PERL...
I have a intel core 2 duo processor can i buy intel DH67VR-B3 motherboard can both procesor and mothrboard b compatible? plz help immediately
i found the product guide for DH67VR i'm not sure if that covers the last 2 characters in the model, however they say this under processor:
Intel Core i7, Intel Core i5, Intel Core i3, and
Intel Pentium processors in an LGA1155 socket:
So I don't think that motherboard will work with that processor, unless the -B3 version of this model has a different socket some intel core 2 duo processors have these socket types: PLGA775, PBGA479, PPGA478, So I would need more information about your processor also. but none of the intel core 2 duo processors seem to fit that motherboard socket.
http://downloadmirror.intel.com/19793/eng/DH67VR_ProductGuide01_English.pdf
May 21, 2012 | Intel Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
hi,
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
5. ABIT IS7
Feb 16, 2011 | ASUS Support Intel Pentium M Processor and...
I have just builed the PC with Supermicro P4SCA and when turn it on I get only the wlecone screen sying "SUPERMICRO" and that itm it never go beyond that. Cltr_Alt_Del does not work and I can not access...
Maximum processor supported: Intel Pentium® 4 processors or Intel Celeron processors up to 3.06 GHz (with Hyper Threading) at a system bus speed of 800/533/400 MHz.
Yours is too fast for the motherboard, replace it with an older weaker one.
Feb 03, 2010 | SuperMicro P4SCA 875P Mainboard...
Replace my D865PERL Motherboard
I really dont know why u need to replace ur MB? Was it giving problems, like overheating? or u want better processor therefore u have to have a MB compatible for that processor, then you'll have to. Otherwise kindly clarify the nature of ur problem..........sodeep
Jan 14, 2009 | Intel D865PERL Motherboard
Uppgrade to a faster processor?
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo  1.8 x 2.4 = 4.32 GHz
Sep 23, 2008 | Computers & Internet
to decide cpu compatability we would know the model of the motherboard.
Robert
Sep 22, 2008 | Computers & Internet
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 05, 2008 | Intel P4 3.0 800 MHZ Retail BOX
Intel D865PERL Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
