Question about iRiver H10 MP3 Player
Iriver h10 20gb not recognized in UMS
My iRiver H10 20gb worked just fine up until recently when it stopped being recognized by any PC I connect it to in UMS mode (emergency connect). I have since tried it on half a dozen computers. Windows XP, Vista, and even a Mac at my college which it always used to work on. I'm running Rockbox software so I can't try MTP either. I thought it might be the cable but have also since replaced the cable. Any help would be greatly appreciated.
  • Zapnut Oct 10, 2008
    Just to clarify a few points - The device functions normally in every other respect. It can also charge from USB. In XP and Vista, it comes up with USB device not recognized, and the device manager sees it as an unknown device and any attempt to manually search for drivers just results in it saying that the best drivers are already installed. When I connect to the Mac, it just does nothing at all...
    Problem Solver:
  • 14 Answers
I sometimes have to reset my iRiver in order for my Mac to see it. I have an h10 5gb, to do this, I have to remove the battery then reconnect the battery. Then I connect it the usual way to get into the UMS mode. But I think with yours it has it's own reset button. If it was working and now has stopped, I would think you just need to reset it and try again.
Posted on Oct 29, 2009
I replaced the battery in my iriver h10 20g. System file missing
was your player set to ums mode before running updater? to put it in ums mode you have to reset player by removing battery then reinstall battery then connect it to your computer turn on player and at the same time hold the button down with the o on it then run the updatera program again
Mar 23, 2009 | iRiver H10 MP3 Player
Iriver h10 not always shutting down properly. Sometimes have to reset
sounds like your power on switch may have an issue or your hard drive is severely fragmented or is going south. Hook up the H10 20gb to your pc via the UMS emergency connection trick (see here) . Try defragging your hard drive first..
Mar 15, 2009 | iRiver H10 MP3 Player
IRiver H10 20 gb System files
check around this forum for an answer: users
Mar 04, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Copy from iriver to computer
connect while in UMS mode
Dec 17, 2008 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
4.6GB Iriver H10 Merory says 2.9GB remaining but there is nothing on the player.
Considered formatting disk?
For you what this would mean is just a complete refresh of the device (you will lose everything).
You will need to read everything carefully.
Check this out
http://www.misticriver.net/boards/showthread.php?t=14853
I converted my H10 to the "UMS" mode mentioned in the site a long time back (so I could directly transfer files as a USB mass storage device) and had the issue mentioned in that post. Works great. Converting to UMS mode is done here http://www.misticriver.net/wiki/index.php/H10_Firmware_Conversion:_MTP/UMS
You will also need the iRiver Plus software that you can download for free here http://www.iriver.com.au/iriver/index.cfm?pageID=10001&
Feb 17, 2008 | iRiver H10 MP3 Player
UMS
Try plugging it in to the computer first while the device is off. Then, hold the O key and press the power button. Worked for me.
Dec 25, 2007 | iRiver H10 MP3 Player
Iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Sep 22, 2007 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
543 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
