Dimension and Scale Factor
1. If a soccer lover has a photo frame that is 180mm in length and 125mm in breadth with a scale factor of 4 .Calculate the dimension of enlargement.
2. If he wanted to reduce the photo frame with area equal to 9cm squared. find the scale factor.
125/180 = 1.5625
Posted on Mar 19, 2009
  • fchidoro Mar 19, 2009
    1.5625x4=6.3
How do i get aquantum ml 29032 scale manager manual?
A Scale Manager kit comprises of the following:
  • One computerised electronic water descaler
  • One 12 volt power supply, cable length 1.8m - 6?
    Optional when ordering, 5m - 16½' power supply extension lead
  • Antenna cable with red plug
  • Antenna cable with black plug
  • Five plastic cable ties (1 spare)
  • One attachable black antenna plug
  • One attachable red antenna plug
Please Note: Ensure antennae cables do not come into contact with each other
  • The gap between the coils must be in excess of 60mm - 2½" no upper limit
  • Coils require a minimum of 50mm - 2? each side of uninterrupted straight pipe
  • Direction of coils is essential - see over
  • Ideally a 125mm + (5?+) straight run of pipe is required for each antenna coil
  • Direction of Water Flow is immaterial
  • Connect red plugs to red sockets and black to black
  • Scale Manager is effective on all pipes (copper, plastic, lead, steel etc)
  • Performance is not impaired if the pipe is painted
  • The Control Unit can be fitted at any angle or plane
  • A 13-amp socket is required for the power supply
The ideal location to install Scale Manager is near the entry point of the rising main, before any junctions. The antennae coils operate independently and can be positioned on separate pipes should you not have an uninterrupted pipe run of 250mm - 10?. Should the inlet pipe T off within 125mm - 10? of the stopcock, position the coils as fig 1 overleaf. If the inlet pipe available is over 125mm - 5? but under 250mm - 10? position as fig 2 overleaf.
The antennae coils require a minimum gap between them of 50mm - 2?. It is also necessary that the coils are at least 40mm -1½" from elbows and junctions.
Dec 30, 2016 | Health & Beauty
Is it possible to calculate factors using a TI-30x IIS
I believe factors can be calculated on any basic calculator.
Starting with 1, increasing by 1 until you get to square root (number) + 1
Let's do an example.
28
square root (28)+1 = 6
Factors
1, 28/1=28
2, 28/2=14 14*2 - 28 = 0 (when you divide, you get no decimal)
3, 28/3=9.33333 - not a factor - doesn't go in evenly
4, 28/4 =7
5, 28/5=5.6 - not a factor - doesn't go in evenly
6, 28/6=4.66666 - not a factor
So now we can list our factors - 1, 28, 2, 14, 4, 7
Putting them in order, we get 1, 2, 4, 7, 14 and 28.
Good luck,
Paul
Jul 13, 2016 | Texas Instruments TI-30 XIIS Calculator
Regular pentagon QRSTU has a side length of 12 cm and an area of about 248 square cm. Regular pentagon VWXYZ has a perimeter of 140 cm. Find the area of VWXYZ. Round to the nearest tenth.
Find the scaling ratio
Perimeter of first pentagon is 12*5=60 cm
Scale factor (2nd/first)=140/60 =7/3
Ratio of areas varies as the square of the scale factor for the lengths
Area of second / area of first =(7/3)^2 =49/9
Area of second pentagon =248 *(49/9) cm^2
Finish the calculation.
Jul 01, 2014 | Texas Instruments TI-83 Plus Calculator
The two pentagons are similar. If k is the scale factor for the lengths, the ratio of the areas is k^2.
Pent 1 side =12 cm
Pent 2 side =140/5 =28 cm
Scale factor (larger over smaller) is k=28/12=7/3
Area of Pent_2= (49/9)*Area of Pent_1
Your answer should be C.
Jun 29, 2014 | Office Equipment & Supplies
The new patio
The figure are similar, corresponding sides are proprtional
L1/L'1=L2/L'2= ... =k , the scale factor for lengths.
However, if scale factor for lengths is k, the ratio of area is k^2 find
Scale factor
Use the given area to find the proportionality factor then use it the ratio of length to find the missing distance between the parallel sides.
Area of new /Area of old=360/250=36/25=k^2
k=SQRT(36/25)=6/5
Ratio of lengths =k=6/5
Distance between parallel sides of new patio/Distance between parallel sides of old patio=6/5
Distance between parallel sides of new patio= (6/5)*12.5=15
The distance between the parallel sides of the new patio is 15 feet.
Dec 17, 2013 | Office Equipment & Supplies
A new patio will be an irregular hexagon. The patio will have two long parallel sides and an area of 360 square feet. The area of a geometrically similar patio is 250 square feet, and its long parallel...
Scale factor
k=SQRT(36/25)=6/5
How are you supposed to know if two shapes are similar if there aren't on a grid.
Use a ruler to measure the lengths of the sides and a protractor to measure the angles. The scale factor is the lengths of one divided by the lengths of the other.
Dec 07, 2013 | The Learning Company Achieve! Math &...
What is the Minimum Curve Radius for Model Trains?
The length of your equipment, even more than the scale of the model, is the most important factor in setting a minimum radius. The list below includes conventionally accepted minimums for each of the major scales.
  • Z Scale: 195 mm
  • N Scale: 9 3/4 inches
  • HO Scale: 15-22 inches
  • HOn3 Scale: 15 inches (narrow gauge)
  • S Scale: 20 - 30 inches
  • O Scale ("Toy"): 13.5 inches
  • O Scale ("Scale"): 72 inches
  • On3 Scale: 36 inches
  • G Scale: 24-44 inches
Jan 10, 2013 | Crafts & Hobbies
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Jan 21, 2011 | Dell Computers & Internet
153 people viewed this question
jasbo
jasbo
