Ic used in which section of philips TV kit
Ic no. is TDA 9370PS/N3/A/1665
Tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Posted on Nov 02, 2010
Service mode
Posted on Jul 31, 2010
Circuit requred
Posted on Aug 13, 2012
Philips model 20pt1344
What is audio ic no..
Posted on Mar 02, 2015
Ckt daigram tda 9370
Posted on Aug 22, 2013
Tda 9370ps/n3/a/1931 using in videocon tv power suply ok,but no EHT,power LED are no glowing
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window. It will make surf easy.
Select the posts titled "My service table today"; by type in this title at its search box at the top right. You can get some details about the service work to this model set.
Jul 08, 2015 | Televison & Video
Tda 9370ps pls tell mr the Blue back pin
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Refer the circuit diagram. It is there. Surf the site with the number of IC " TDA9370 "as keyword.
Jul 03, 2015 | Televison & Video
IN LG TELIVISION USING TDA 9370PS N3 1774 THE VOLTAGE AT THE COLLECTOR OF H DRIVER TRANSISTER BECOME 0
Disconnect the base of horizontal drive transistor, and now check it collector voltage. If it is found OK; [almost equal to its iput voltage]; check the voltage that comes to its base, from the IC pin. It should be below 0.1 to 0.25V. If found higher than this, the IC is faulty. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Daewoo Televison & Video
Service code for vediocon tv usig IC TDA9370ps/1932
WE WANT VIDEOCON CTV IC 9370PS SERVICING REMOTE CODE
Mar 13, 2012 | Televison & Video
Chaild lock use ic tda 9370ps/n3/a/1930 ic &memo (remcon ic 24c016) rep but same prob i m a tech pls help me
You have to go through the MENU mode and clear it. If it is not clearing, you have to change the main IC.
24 CO16 is a programmable chip. You can not use it as it is. you have to program this. Better take help from the mfr service provider.
24 CO 16 series are eeprom and they never get corrupted! You have to check the main IC.
Aug 22, 2010 | Televison & Video
In sansui television. is not working properly. in the remote. but front panel is working. i have changed the remote also . but problem remains. then i changed the sensor. it remains. then changed the...
dear,i also had suffer from it's service menu code. in some days ago i had been seeing a web site, their was had every service menu.then i got your sansui tv model.your sansui "ctvk2k21"model's in the IC no. is "tda9370ps/n3/a/1932" service menu is press "menu(from remote) & 0,3,2,3(from remote)".for more information call me for in any electronics gagged problem.
Aug 15, 2010 | SansuiM1315 TV
OK I FOUND TDA9855 IS THIS IT!!!!
Your looking for a 9 pin IC that one there is for the stereo decoder. Solder the one you found near where it said vertical deflection as the IC will be near that section of the board
Jun 01, 2008 | Philips Magnavox 27MS343S 27" TV
TDA 8364
Look it up at nteinc.net
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
669 people viewed this question
Top Televison & Video Experts
Electro Med Services...
