Question about JVC HD-70FH96 70" Rear Projection HDTV
JVC HD-70FH96 both HDMI problems
Last night Oct 8 2008 I installed a new sony Blu-ray player. As both of the HDMI ports were already in use I also bought an HDMI switcher unit. I hooked everything up and presto everything was good. This evening I got nothing after turning on the TV. I removed the switcher unit from the circuits and still nothing from the HDMI jacks I tried several combinations of the sony player, the LG DVD recorder, and Diredtv HD DVR sat receiver. I got nothing no picture, no sound. I Tried the TV menu, andthe menu appeared on the screen. I reconnected everything to the component, inputs, and composet, inputs and all is well, but still no joy with HDMI. what happened? Is it an easy fix? expensive? what?
  • stevenschont Apr 25, 2009
    My HDMI used to let me use my blueray player on it but now it does not and I have tried using different cables and different blueray players but nothing but it will let me use my satellite on with the hdmi port what is the problem
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Posted on Oct 10, 2008
My philips 42TA648BX/37 hdmi sound is wrong
The problem could be only in the input device or in the transmission.
Aug 11, 2012 | Philips Televison & Video
I have a denon avr 1610 and it is connected to a sony blu ray S370. when i play a blu ray the HD sound i.e DTS HD-MA and Dolby True HD does not give proper sound and when turn on the full volume the there...
Make sure you have connected the blu ray players HDMI out to the Denon's HDMI in. HD sound is passed only through the HDMI port. And in the BD370's sound menu disable downsampling ( i.e enable uncompressed PCM audio for HDMI ).
Jun 23, 2011 | Audio Players & Recorders
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
May 16, 2011 | Sony BDP-S350 Blu-Ray Player
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
HDMI not working Sony BDP-S350
plug the sony player into your home network via a network cable ( should be a network port ( RJ45 port ) on the back of it and then update the firmware - unless its already the latest version, if it is then post back with any error messages or whats happening exactly when you try to select HDMI or is it greyed out ?
Jun 02, 2009 | Sony BDP-S350 Blu-Ray Player
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
JVC HD-70FH96 70" Rear Projection HDTV Logo
576 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
