Question about Mitsubishi WS-73907 TV
Help, Help, Help! Mitsubishi 73" red convergence fiasco
I have an older (?) Mitsubishi WS-73907 series and cannot correct its red convergence. I have located the manual convergence feature in the menus, and can alter blue convergence fully, and can alter red convergence in the up/down direction, but NOT in the left/right direction. Every so often, for a very short period of time, the convergence will "magically" be correct, but then quickly goes back to out of whack in a complicated sinusoidal (?) pattern, with the error being zero in one location (right of center) and then progressively worse toward the sides and corners.
How can I fix this? I've been watching this giant doorstop out of focus for many weeks now, but can't stand it any more!
  • 2,071 Answers
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Posted on Oct 10, 2008
My mistubishi WS-65713 73 inch tv's colours are off. There is mostly blue and green and some colours are non existent like red and yellow. What is the problem?
Sounds like a convergence problem which is common in these sets
This model uses two of the stk394-250 convergence output devices or chips.
Both would have to be replaced.
Mar 12, 2012 | Mitsubishi WS-65813 65" Rear Projection...
Convergence is way off, Rt & Lf side of screen has red & blue around objects
Convergence IC's inside of your TV have to be replaced. Also some low value resistors around IC's could be burned as well.
Then convergence have to be realigned. This job require above-average soldering skills and cost around $300 if you hire TV repairman to do that.
Regards.
Russ.
Apr 04, 2010 | Mitsubishi WS-73907 TV
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Red / Green issue when connecting Mits DVD to Mitsubishi TV
if you just moved it i would look for loose connection arouind the convergance amp ics
do not play the tv....
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Mitsubishi WS-73905 73" Rear Projection...
Picture slightly too big
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 08, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-73907 TV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
