Hyundai tv - child lock?
I have a fairly old hyundai 74cm flat screen tv, i don't have a remote and I was going the the menu manually when I selected child lock by mistake!! how do i get this to disable without a remote, please help, as I can't watch tv!!!!
5 Suggested Answers
  • 4 Answers
SOURCE: 27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
hi just thought id let yo all no i had the same problem with a waltham but all i had to do was use a phillips remote that was lying around it had all the right buttons and was for a normal tv 32" not hd or flat =0) im not saying this will help every one but its possible that other remotes might work too!
p.s. its worth a try
Posted on Jun 30, 2008
SOURCE: Child lock in a Koryo TV 21inch.
Go to the channel where Child Lock is ON
Press " --- " Key ( below channel 9 button) for few seconds,
Child Lock will be OFF
Press again Tune Lock will be OFF.
Posted on Jul 31, 2008
dumbtrucker
  • 102 Answers
SOURCE: magnavox 27ms343s tv won't turn on manually or with remote, help
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Posted on Mar 24, 2009
praky16
  • 744 Answers
SOURCE: How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Posted on Apr 10, 2009
SOURCE: child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
I waqnt reseat child lock off witout remote controal i dont have a orignal remote controal tv digihome model no32723hd
It might be impossible to release the child lock, without its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 26, 2014 | Digihome LCD TV
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Son lost remote for his tv and the child lock has come on how do i turn it off
THE SOLUTION FOR THIS FIX, AS IT WORKED FOR ME....I WAS LOCKED OUT BBY THE DUMB CHILD LOCK FOR TWO MONTHS, BOOUGHT A NEW REMOTE THAT DIDNT WORK....GET A 10$ REMOTE FROM THE STORE, AND ENTER CODE 0224 IT KILLS THE CHILD LOCK FEATURE..THEN YOU CAN POWER ON THE TV..GO TO MENU AND SELECT CHILD LOCK AND DEACTIVATE IT! THANKS ALOT MAGNAVOX..IT WAS NOT IN THE MANUAL FOR THE TV OR THE REMOTE FOR THE TV EITHER......CAPERS~
Oct 04, 2011 | Philips Magnavox 27MS343S 27" TV
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
Videocon tv ----on screen showing sorry panel is locked .....no tv set or remote button's are working .tv model is videocon 5440V-R karaoke.
Your panel is locked due to child lock. Procedure to unlock it may be given in the operating manual.
sonsunny
Jun 17, 2011 | Televison & Video
My 4 year old son has managed to put the child lock on my lg tv and i cant find a way to get it off
The 26LC2R front panel lock is accessed from the Menu. Since it is locked, you will need the remote (or one that matches the Menu function). Press Menu, then use the up/down arrows to select Special. Then press the right arrow button and go up or down to Child Lock. Press the right arrow and select Off. Then press Exit or Menu.
The manual is available here: http://tv.manualsonline.com/manuals/mfg/lg/26lc2r.html .
I hope this helps.
Feb 20, 2011 | LG 26LC2R 26 in. HD-Ready LCD Television
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
Child lock on, TV off, No remote or manual=cannot turn TV back on
i found out on line in the owners manual that if u still have a remote control that came with the tv, u press the tv/av button and enter button at the same time to disable the child lock. New problem: u can't do it with a universal remote, even if its programmed to a magnavox tv. I called the 800 # to buy a remote control and the rep told me that it cost $50, not including the shipping and handling. so my husband put the tv in the car, brought an extension cord and took it to a local tv repairman who was kind enough to use his remote to remove the child lock for us. finally someone who is helpful for free. thanks to all the nice people out there!
Jun 16, 2009 | Philips Magnavox 27MS343S 27" TV
Unlocking Logik TV set
If you have child lock on a logic tv. On your remote the bottom where the button is music / sound. Hold in for 5 minutes and the lock will come off
Jul 16, 2008 | Televison & Video
Lack key appear on my flat screen
Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
Mar 09, 2007 | Sony 21" Trinitron P202 Flat Screen...
Televison & Video Logo
377 people viewed this question
Top Televison & Video Experts
Electro Med Services...
