Question about Whirlpool AWM5145/2 Front Load Washer
Deter dispensing I have a whirlpool sixth sense front loading washing machine. Wash goes thru the complete cycle, but the detergent remains unused. Please advise. Thank you in advance for the help.
  • 5911 Answers
SOURCE: Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Posted on Sep 03, 2008
  • 99 Answers
SOURCE: Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
Dont overload machine the clothes wont smell clean.
Posted on Feb 07, 2009
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
  • 32 Answers
SOURCE: Calypso washer - LD Code - clothes still wet
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Posted on Jul 24, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Whirlpool front load washer w/bulk dispenser - over several wash cycles, the dispenser slowly fills with water and dilutes the detergent.
Apr 22, 2017 | Whirlpool Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ... > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ... > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
F6 e2 on front load whirlpool
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Mar 12, 2013 | Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
When my washing machine is on the wash cycle and it is using the detergent... water and soap suds pour out of the detergent dispenser and run down the front of the washing machine, why? I use proper front...
There is an article of clothing stuck inside the dispenser housing. Remove the top and the housing to get to the hose and clean it out. Very common issue, I know this unit very well.
Apr 22, 2011 | Washing Machines
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
