Question about Whirlpool ARG930 Compact Refrigerator
Sound of Water coming from internal backside of freeze
I have just new bought (1 day ago) new Refrigerator,Whirlpool Fusion 21 Supreme (200 L). When i open freeze, there is sound of water dropping coming from the internal backside of the refrigerator but there is no water dropping inside & outside of the refrigerator.Is there any fault in my new refrigerator so that sound of water dropping coming?? If it is fault then what will be it's solution.
    Scholar:
  • 142 Answers
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Posted on Oct 10, 2008
Lg refrigerator leaking and freezer issue
Honestly, most people are not experienced on LG to know all the symptom and their solution. I guess you will have to wait for it to break again to have it fixed.
Oct 25, 2013 | Refrigerators
I have a new GI5SAXVY01 AND EVRERY DAY OR SO I GET A POOL OF WATER NEAR THE RIGHT FRONT DOOR. IT IS RUINING MY NEW CABINETS.
First you need to determine where the water is coming from - inside the freezer/refrigerator or from underneath. I am going to guess it is coming from underneath the refrigerator after a freezer defrost cycle. The evaporator pan is overflowing or it has been misplaced or the evaporator fan is defective.
If your refrigerator is new, it should be under warranty. You should call Whirlpool and order a service call or return the refrigerator to the store where you bought. Why should you go through the stress of figuring out what is wrong and trying to fix it. In the process of fixing it, you may void your warranty!
I hope this is helpful to you. If nothing else, it should put the problem in perspective. Make the jokers at Whirlpool do the right thing. You paid good money with the expectation of receiving a good refrigerator. It is not right that you have a problem with a new refrigerator.
Jan 29, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The lights are on but it is not cooling or freezing
The overload/relay is shorted . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Pt # 8201786 . Remove the back refrig panel to access the compressor . This part is easily replaceable . Instruction come with the part(s) . A little plastic "clip" needs to be released , when removing the plug from the part , by using a small screwdriver .
Sep 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water & ice dispenser problem
Ensure there is proper water pressure and volume to the unit....replace the water filter....all should be fine.
clarkco
Apr 29, 2009 | Refrigerators
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side, 7 years old. not making ice
try using a hair dryer to thaw out the trough and remove the ice. please note the ice will run all the way up into the tube where it comes thru the cabinet.
this may have occured from your recent filter change as a new filter introdues alot of air into the water system and will cause these tubes to freeze up. in the future right after you replace your filter be sure to run aout 1/2 to 1 gallon of water thru water dispenser to clear air out of system. thx peyton
Jan 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool ARG930 Compact Refrigerator Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
