Fuzzy Rear Screen Projection TV
I'm hoping you can point me in the right direction as I live in a semi-remote part of Alaska with no technicians. I'm not totally unfamiliar with electronics (I'm an electrical engineer by trade), but I've never repaired a television set. I have a Zenith 52" rear projection TV (8-10 years old but the circuit board was replaced two years ago). Recently the image started to get fuzzy. It began by slowly fading fazzy and clear every few minutes but now it's permanently fuzzy. I cleaned the lamps and the mirror, and while it helped, it didn't solve the problem. The color is fine, so it doesn't appear to be a convergence problem. Any recommendations?
    Top Expert:
  • Televison & ... Master
  • 24,763 Answers
Probably the EHT unit is failing or the Focus Control is out of adjustment or if it gets worse as the brightness increases, may need a new TV.
Posted on Apr 02, 2017
SOURCE: Convergence problem on rear projection Panasonic PT53WX42?
Chris Palmer gives detailed instruction on how to replace the convergence IC's. Go to his blog at:
Posted on Sep 26, 2007
  • 1030 Answers
SOURCE: Color Convergence
you will have to go into what is known as service mode... have to have a code to get into it
Posted on Jan 18, 2008
  • 8617 Answers
SOURCE: model 34pw8520 picture got fuzzy,
sounds more like the flyback. What is the chassis number of your set. The flyback if thats what it is would cost under 50 if you replace it yourself maybe 150 if a shop does it. But post the chassis number as the chassis number would make it easier to try to figure out if its the flyback or not.
Posted on Mar 24, 2008
  • 8617 Answers
SOURCE: 1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Posted on Apr 10, 2008
  • 19396 Answers
SOURCE: Regarding a Zenith Rear Projection
Looks like the crt board is having some problem
Posted on Jul 08, 2008
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
We have a 55inch sony rear projection TV and it is stored for the winter but its down to 10 below zero will this harm the tv if we leave it for the winter we live in alaska
Your TV is not a rear projection it is a DLP if had been a rear projection the answer would have been YES! Cold would damage all 3 of Tubes But you have a signal Lamp so TV should be OK.
Dec 08, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Green out of alignment on samsung rear projection tv
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Philips 9P6040C 60 in. Rear projection
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
You need to replace the convergence chips and convergence resistors. Check the site . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi Projection on/off problem
Tell me what it does when you try turning it on...accordianman
Feb 17, 2008 | Hitachi 50UX57B 50" Rear Projection...
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
