Question about Philips 42FD9954 42 in. Plasma HDTV
Screen goes black,with sound
Screen goes black,some times only half screen.sound is on,it happens when its on for about 1 hr.please help
  • romypautsch Oct 20, 2008
    I have no screen display. It was working til last night. There is a red sensor light flashing and everytime I press the power button nothing happens...including the sound of the power when turned on. Hope this makes sense.
  • 2,071 Answers
No picture sound ok
Note 1 a Raster is the name for a screen made of lines of brightness
Note 2, A Blank raster has no snow or picture, its just a lit up screen
Sound ok but no raster.
First increase tube's first anode voltage (knob on the loptx) to see if the screen is just too dark.
if after you have turned up the bottom knob on the loptx, there is still no brightness,check, for crt heaters, and EHT 25kv and focus voltage (2kv) and A1's/Screen/G2 voltage is 300-600v.
and check for field timebase (height), the next thing to check is the sandcastle pulse.
If it's present, colour decoder chip is probably faulty or lacks supply from the LT regulators.
NO LINE DRIVE If it's absent,check the line driver, locate the loptr(big and usually has heat sink).
follow the print from the base back to the driver stage , where you will usually find a tiny transformer with 4/5 pins
resolder it, even if it looks good,then with power on, check for voltage on all its pins, 2 should have LT(12v to 32v) or HT (90v to 150v), if not there follow the print back and look for either a transistor(linedrivetr), or the feed voltage line (maybe regulated),
If the voltage is ok on two of the driver transformer(drvtx) legs, the look from the base of the driver transistor to locate the timebase chip
and check round its pins for a 12v supply line, if there ,replace the timebase generator chip
Method of testing line drive, remove line output transistor, and connect a normal red led, across the B/E (longest leg to base), and when you power up the led should lite up.
Trace the pcb back from the BASE leg to find the line driver stage,
Its usually a very small transformer (4/5 legs) and a transistor connected to it,
The driver transformer legs(pins) will be two with voltage and two without
The two with power will either be about HT level (110v=145v) or about LT level(25v)
If not then trace back and look for a biggish 3w resistor.
If the voltages are correct the look for line pulses from the Timebase oscillator chip to the base (some overvolts protection circuits remove pulses if ht is too high).
If the voltage is low and the feed resistor is getting hot then check the base of the driver transistor if its HI over 0.5V then its being turned on by the timebase oscillator chip (protection ?)
If the voltage is zero check the feed resistor
If all seems normal check that 12v is getting to the timebase oscillator chip (IC) (12v regulator?)
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Occasionally my screen goes black on the top half if i switch it on and off a few times it works ok but then without warning it happens again why does it work for hours then go off for no reason help...
you have to be inclined to understand electronics and high power voltage cautions:
see if this link helps you diagnose:
www.alternative-health.co.uk/panasonic.pdf
Nov 06, 2010 | Panasonic TH-50PX75U Plasma HDTV
Screen goed black for half second
Check all ur signal connecttion correctly tight and screws,still happen hit the back cabinet couple times, if it occur ur tv have bad soldier joints or lose connection some where in ur electronic boards.
Aug 12, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Picture in the lcd screen is going partially black
disassemble and check for water or keep the battery at least half-charged
Jun 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
61'' SONY Rear Projection KP 61HS10 blinking
My Sony HiScan 61" intemittent black screen for couple of seconds. I opened the back and look at what is happening. All three blue, green and red projection lights go off for a second or two frequently.
Anyone know what is the fix.
thanks
James
Mar 25, 2009 | Sony KP-61HS10 61" Rear Projection...
SCREEN FAULT
There is little we can do without the make and model. Can you post those please. Each set is a bit different and I'd like to give you accurate information.
Thanks for your help,
Dan
Jul 30, 2008 | Televison & Video
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Philips 42FD9954 42 in. Plasma HDTV Logo
186 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
