Question about Refrigerators
I have an NEC refrigerator model FR480 eight years old that has stopped cooling. Called the technician who can't get information with regard to the electronic controls. It appears that the compresor and coolant are in order, but a signal is obviously being being sent to the equipment to stop cooling. With its relatively young years it seems incredible that it has already broken down and being advised to replace. Can you assist. Pieter
  • telorin Oct 15, 2008
    ADDITIONAL COMMENTS.
    The thermostats are apparently ok according to the technician, he believes that the problem is with the electronic control box on top of the fridge. In Australia NEC won't or cannot provide a service manual for this model and consequently it it just guess work trying to identify the source of the problem. It is also believed that these fridge models were made by Daewoo in Korea and badged as NEC.
    Access to a service manual would help.
    Pieter
  • Refrigerators Master
  • 19,396 Answers
The only signal that can be sent to the equipment to stop cooling is the one from the thermostat. This is infact turning on and of the cooling system (compressor, fan , etc).
Did the technician test the thermostat?
If cooling is poor, another reason for poor cooling is the evaporator system preventing the coils from freezing at the back, see here:Cooling is poor
If there is not cooling at all, than can be a problem with the thermostat, the compressor, the evaporator fan, or a couple of relays that controls the load on the compressor. See here: It's not cool
If your fridge had just been repaired, call back the technician, ask him to check the parts descripted above, and have it fixed .
By inserting model number here you can get part list, part price and exploded views.
Here is also a general diagram Freezer on Top
Posted on Oct 15, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, do you mean the signal to stop cooling is faulty?
I guess the thermostat is faulty. Its the one which detects the temperature and send signals to the circuit.
Posted on Oct 10, 2008
This model FRC445GM of mine has stopped running is there a reset button. Fridge is only 2yrs old
Good Afternoon Lenette,
I understand that your Frigidaire compact refrigerator, model# FRC445GM, has stopped running. There is a way you can reset your appliance. You will want to unplug it for 3-5 minutes. Once time has passed, plug it back in. If your refrigerator is still not cooling, I suggest contacting either the manufacturer, or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire FRC445GM Stainless Steel
NEC FR480 Fridge not cooling below 21 degrees
sorry, but you can visit <a href="http://www.raybansshop.co.uk/">Ray Ban uk</a>
Sep 15, 2011 | Refrigerators
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
Older Kenmore side by side stops cooling, both sides
1st. >Check the defrost timer first.You should be able to turn it with a screwdriver.
2nd.>bypass the temperature control and if the Fridg. turns on ..replace the control.
Please Rate this !!! thanx ! I'll assist you if you need further help.
Dec 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Frigidaire refridgerator #frt21prhw1, not cooling or freezing
You said, your frigidaire refrigerator are not cooling
Check the outlet that it is still has power. You can plug a small lamp in to test it.
If there is power, wait 5 minutes before plugging the fridge back in and then see if it reset the system.
And how old is the fridge?
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Refrigerators
My fridge stop cooling including the freezer section, motor is running okay. This is a icemaker fridgedair. Help , please.
Hello kenbarn
Welcome to Fixya
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
Repair or replace?
Thank You, HUUUM
Oct 05, 2008 | Frigidaire Refrigerators
Stopped cooling
Hello cpuklutz
Welcome
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it even makes any financial sense to get estimate to repair, or is 10 years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation.
Repair or replace?
When a repair makes sense.
Thank You, HUUUM
Sep 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
428 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
