Question about Creda W120VW Front Load Washer
Creda supaspeed 1000
I LIVE IN BROOKLYN NY NEED A PART THE LATCH ON FRONT LOADER OPEN AND CLOSE DOOR . WHERE CAN I PURCHASE THIS PART IN BROOKLYN NY OR DO U HAVE ANOTHER SOLUTION HOW TO CLOSE THE DOOR SINCE LATCH BROKE.
3 Suggested Answers
  • 74 Answers
SOURCE: Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Posted on Feb 17, 2008
  • 5 Answers
SOURCE: door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Posted on Apr 04, 2009
Hi my creda t522vw dryer door won't close
This has happened on some of the front load commercial dryers in one of my building. The door alignment pin that mates with the latch was not meeting in the center of the latch. On one of the dryers the latch pin broke, I replaced the pin and thought I had fixed the problem. After a second parts search and realizing how much work it would be to open the front of the dryer to replace the hinge, I opened the door just enough to clear the housing and lifted up on the latch end of the door to try to bend the hinges back up. I had to pull up with more force than expected, but the door alignment was better and the latch mated properly. I then got out my RED Sharpie and wrote on the top of the, "PLEASE DON'T LEAN ON THE DOOR" The problem has not returned.
I hope this was helpful.
Jun 02, 2014 | Dryers
Creda 1000 supaspeed manual
No spining ,i remove the brush holder clean it coz the brush stucked in and was not three , then mount it back, check for proper contact to rotor and on it back to normal- In a second fault the bushes was out of use so i purchase a pair and rub it to fit the size as it was not available on market, now it is running fine.
Oct 31, 2010 | Washing Machines
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
I need the manual for a creda supaspeed economy plus model 17064Echa642
The users manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/INDESIT/P%20640%20AS-_E
Kind regards,
Ian
Nov 29, 2009 | Creda Washing Machines
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Door won't open at end of cycle Creda 1000 ecowash front loader
Apr 04, 2009 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Mar 20, 2006 | Creda W100FW Front Load Washer
Creda W120VW Front Load Washer Logo
89 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
