Question about Pentax Cameras
What polarity is the pentax L30's dc jack? - Pentax Cameras
  • craquer69 Oct 10, 2008
    the DC jack on the side of the camera is polarity dependant i am replacing the power supply/battery charger i need to know the correct polarity. ie centre pin positive or negative
  • craquer69 Oct 11, 2008
    inner positive outer negative
  • 10,594 Answers
Internal pin is for + volts and external is for - volts
Posted on Oct 10, 2008
  • Shahid Electronics
    Shahid Electronics Oct 10, 2008
    Center pin is positive and outer ring is negative.
    hope you received solution email.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Normally all chargers have correct polarity. Neways,
Check this picture of the power plug.
http://www.coding4fun.net/images/ComputerControlledRCCarwithCamera_525E/CIMG01904.jpg
The outer metal surface is negative and the inner (hole) is positive. So, now you know which part (in your camera socket) is positive and negative.
    Scholar:
  • 116 Answers
Please mention some more details about the problem.to make it clear and explainable.
reply.
  • 1 more comment
  • mastermind10 Oct 10, 2008
    The interchangeable
    DC plugs included are for center plus and polarity
    protection. Any setting of the output voltage
    selector switch is protected against unintentional
    change of voltage. A power on LED and 2 rubber
    grips for easy handling rounds off the high
    specification of a neat, compact and easy to carry
    power supply for worldwide use. Output voltage in
    6 fixed steps 2.4v, 3v, 4.2v, 5v, 6v, 6.5v, 7v,
    8.4V to match the voltage specifically needed for
    most digital cameras. 5 inter changeable centre
    plus and polarity protected DC plugs included.
    (Plug dimensions 1.7 x 4.75 / 1.7 x 4 / 1.4 x 3.5
    / 0.75 x 2.4 / 5.5 x 2.1 all right angled plugs).
    Congratulations on your purchase of the Sima SUP-2 Universal Power Adapter. It
    can power digital cameras and other portable electronic devices requiring 3.3 / 4.2 / 5.0
    / 6.5 / 8.4 or 9.5V DC power. The SUP-2 can also provide power for other devices. It is
    fully regulated using high efficiency switching technology and features overload and
    short circuit protection. The SUP-2 comes with seven connectors to fit different digital
    cameras and other electronic devices. Additional connectors are available from Sima.
    This package Includes:
    1 AC adapter 7 Center pin positive connectors
    1 12V car lighter cord 1 SUP-2 This Manual
    Operation
    1. Set the output voltage switch, as illustrated in Fig. 1, to
    the desired output for your device. Choose from the
    following settings: 3.3 / 4.2 / 5.0 / 6.5 / 8.4 or 9.5 V.
    The SUP-2 comes with seven standard connectors. The
    connectors allow you to match the size and polarity of
    your device’s DC input jack. If your device requires other
    types of connectors, contact Sima customer service at
    800-345-7462.
    The connectors supplied with the SUP-2 are all set in a
    center pin positive alignment ( Fig. A) If your device
    requires a center pin negative power source (Fig. B)
    do not use this adapter.
    To determine the required
    current and correct polarity for your device, refer to the
    manufacturer’s instruction manual or specifications
    2. Select the appropriate connector and attach it to the output socket at the end of the
    output cord. The connectors are numbered as follows: 1, 2, 4, 5, 13, 14 & 17. To
    identify the correct connector for your camera, see the list of digital cameras on the
    reverse side of this sheet. If unsure, use the connector that fits the power jack of
    your camera. The three-pin connectors are designed to fit into
    the socket in only one position. Align the pins as shown at
    right in Fig. 2. Do not force.
    3. Insert the connector into the power jack on your portable device.
    4. Plug either the AC adapter or the car cigarette lighter cord
    into the SUP-2’s input power jack located at the top of the
    unit. Note: Do not plug the AC adapter or car cord
    directly into anything except the SUP-2.
    Next, plug the
    AC adapter (or car cord) into a standard AC wall outlet (or
    car lighter). The red power light on the SUP-2 should turn
    on. You can now operate your device.
    IMPORTANT:
    Your portable device must be rated between 3 - 10V DC and no more
    than 2100 mA of current to use the SUP-2. If the exact voltage for your device is not
    listed below and is less than 10V, you can try setting the voltage switch to the
    nearest voltage – use the lower setting first. If the device does not operate, disconnect
    the connector from the device, reset the voltage switch to the next higher setting
    and re-connect. Do not continue trying higher settings as they may result in
    damage to your device or the adapter.
    The SUP-2’s current (mA) must be equal to or greater than the current your portable
    device requires. Remember 1A = 1000mA, 0.5A = 500mA. Use the following chart
    to determine the output current from the SUP-2:
    Output Max. Output Max.
    Voltage Current Voltage Current
    3.3V = 2.1A 6.5V = 1.7A
    4.2V = 2.0A 8.4V = 1.6A
    5.0V = 1.9 A 9.5V = 1.5A
    Resetting the Adapter
    CAUTION
    : If the power light turns off, check the power source. If on, the output current may be
    beyond the AC adapter’s specifications and the overload protection has been activated.
    To reset the adapter:
    1. Disconnect the AC adapter from the AC outlet and the device you are powering. Wait 10 seconds.
    2. Plug the AC adapter into the AC outlet again. If the indicator remains off, there may be a problem
    please check out this link for more better help as this includes the diagrams of the sides which negative and which positive and how to take care of your deviice to avoid further problems
    http://www.simaproducts.com/support/file...
    just click the above link and the page will display on your screen.
    thanks.
    for any thing else feel free to comment.
What is the polarity of the dc power lead
Hi, using a continuity tester, check point of Jack connects with shield (external metal square) of USB connector, that´s minus ( - ) polarity.
Feb 07, 2016 | Computers & Internet
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
My Pentax Optio L30 is on green modr so the lens zooms in and out and the camera shuts off how do I change it
to solve this problem go to www.justdeals.com, they have this camera for just 38 dollars, is that a good solution?
Jul 20, 2010 | Pentax Optio E40 Digital Camera
I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Jul 13, 2010 | Sangean ATS 818 AM/FM/SW Radio
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Oct 07, 2009 | Casio Music
What is the ac polarity of a fujistsu lifebook c2330?
In household and commercial electronics 110-125 AC has no polarity unless there is a safety ground, in which case the green safety is connected to to the white wire via earth ground. Black is "hot" meaning if you touch it you will feel a shock because your body connects the circuit to ground. A laptop operates on DC power delivered from an AC-DC converter usually around 20 Volts dc and 3.5 Amps, and charges the battery as well. Polarity of your computer is positive tip meaning the fat part of the plug going into the jack is ground, or negative, and the center is positive. I hope this helps.
Jul 05, 2009 | Fujitsu LifeBook C2330 Notebook
Lucent AT&T 7610 Cordless Phone power supply
It should be labeled on the side of the phone. My best guess would be AC/DC...as to polarity, you would have to look at the drawing on the side by the jack...
Jul 27, 2008 | Lucent AT&T 7610 Cordless Phone (22063)
Dc jack
This is usually quite a tricky repair on laptops as you'll need to solder the new jack socket to the motherboard in the laptop.
If you cant get the original socket, you could get a chassis mounted socket, mount the socket onto the case where the old jack was and fix it in place with a nut. Then solder 2 pieces of wire from the socket to the motherboard.
Watch the polarity though, else you'll have a fried motherboard!!!
Jun 25, 2008 | Sony VAIO GRV680 Notebook
Cameras Logo
75 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
